Encoding decoding bits of a byte
Hello
id, like to find the way to split a byte into halfs and get the representative of each half as a decimal number.
I explain a bit , i,m sending lots of values to Arduino Mega via udp ethernet shield. i need to send 512 Set of values maximum of 5 values each.
as i,m sending now
[FirstValue][SecondtValue][ThirdValue][ForthValue][FithValue] X 512 = 2560 bytes which are too many
those are the value ranges of each value:
[0-31][0-16][0-7][0-7][0-7]
as Ethernet shield has a max buffer of 1500 bytes i can not send all data i need in full bytes.
so as i,m not using the full value of the unsigned 8 [0-255]i,m sending i wanted to split those into 2
so for now i would like to concentrate and know how to convert those 3 bytes [0-7][0-7][0-7] into 2 bytes data instead of 3 .
for example if i send the values of [6][1][2] i would send 2 bytes containing the first the value :
of 61 and the second the value of 20
so first one split to get 6 for first and second 1 .
i would send the value of 3D in hex for the 61 that will become 2 values of 6 and 1 .
do you see what i mean ? maybe you have better ideas but i think this one could work if i get how to do it in Arduino.
can you please give me some hints and guidance about it ?
Have a look at the bit shifting and bitwise and/or operators.
Here is something to start you off
byte aVar = 0b10100101;  //decimal 10 in msb and decimal 5 in lsb
  int msb = (aVar & 0b11110000) >> 4;  //get the first 4 bits of the byte and shift them right 4 places
  int lsb = aVar & 0b00001111;         //get the last 4 bits of the byte
  Serial.println(msb);
  Serial.println(lsb);
[0-31][0-16][0-7][0-7][0-7] can be packed into 19 bits but if you round up to byte boundary that's 3 bytes (24 bits) x 512 = 1536 bytes
You still wont be able to send the entire data set in one packet. You would pack/unpack the data using the bit shift principle outlined by UKHeliBob
Hi thanks for your answers
i,ll read more about it.
in the end i,m going to send only 3 parameters in the range of [0-15] [0-15] [0-15]
so i can send them all in 2 bytes x 512 , 1024 which then i,ll be able to send to ethernet shield.
what will be the right way do it ?
1 byte convert to binary and do the spliting shifting or join all 2 bytes put all binary in a row and do the shifting ?
I'm puzzled by the requirement to cram your data into a single packet - is there any reason why you can't send several?
It is not the most efficient, but it is well known and simple, I suggest you google "Binary coded decimal", if you have never heard of it.
colorsound:
Maybe not the most elegant or efficient code but something like this example.
byte a = 0x1A;
byte b = 0x2B;
byte c = 0x3C;
void setup(){
  unsigned int r = 0;
  r = a & 0x0F;         // Copy a to r, masking to keep lower nibble only
  r <<= 4;              // Rotate right r by a nibble (4 bits)
  r = r | (b & 0x0F);   // Or the lower nibble of b with r
  r = r | (c & 0x0F);   // Or the lower nibble of c with r
  Serial.print("a = "); // Print the results
  Serial.println(a,HEX);
  Serial.print("b = ");
  Serial.println(b,HEX);
  Serial.print("c = ");
  Serial.println(c,HEX);
  Serial.print("r = ");
  Serial.println(r,HEX);
void loop(){}
If you're not comfortable with bit shift and mask operations, there are the bitRead and bitWrite macros
Hi all thanks for your tips and suggestions
i got some better idea and played with bit Read functions , although in those i did not see easy way to rotate the nibble easily .
byte a = 0x1A;
byte b = 0x2B;
byte c = 0x3C;
byte Converted;
void setup(){
for (int i =0; i < 8; i++) {
  Serial.print(bitRead(b,i) );
  Serial.print(" ");
  Converted = bitWrite(Converted,i,bitRead(b,i));
  Serial.println(Converted);
void loop(){}
@wildbill
i,m sending those values to change pixel colors , there are time were all pixel are send therefore i need to send the whole packet , this is how i have it and works very fast only missing some pixels because the ethernet 1500byte buffer limitation , but after i can compress it will be perfect.
I,m a bit confuse in how to do the encoding as for example if i send
2 bytes with [0-15] [0-15] [0-15] like 121 102 and split into 2 i get the appropriate values for each 12 11 02 so this could be done without the bit tricks. the problem is when i send values with one digit only or starting with 0 , i can do the padding in computer side but it will remove the 0 in conversion so for 020010 this should be a value of 2,0,1 . but it will send the bytes like 2010 so i will miss the real value.
so if i do it using bits will this happen too ? , what will be the procedure , i convert it piece of the 020010 to binary and then those to hex and send this character and in arduino do the bit splitting ?
cheers
hi guys
ok i got it , now i found the way to encode the bytes in computer side correctly , so i will send 2 bytes like this :
4F 00 it should generate values of 15,4,0
20 06 it should generate values of 0,2,5
2F 0F it should generate values of 15,2,15
0B 07 it should generate values of 11,0,7
so i guess to decode in arduino i need to use the << operators right ?
Or use bitRead on the input data and bitWrite on the target variables
hi
i got it working ;D
in the end i did like that :
being CleanBuffer the 2 bytes i get from udp:
uint8_t lsb_R = CleanBuffer[0] & 0b00001111;
uint8_t msb_G = (CleanBuffer[0] & 0b11110000) >> 4;
uint8_t lsb_B = CleanBuffer[1] & 0b00001111;
uint8_t msb_A = (CleanBuffer[1] & 0b11110000) >> 4;
thank you guys ¡¡
