Hey Everyone!
I got an endstop switch on amazon:
and I am using it as an interrupt for my motors as well as setting home, which is working great but each time I click the switch it stops the command 3 times, once from when I press it, and twice from when I let go. The goal is to have the interrupt work only when the switch is pressed, and completely ignore being held down or released. Any ideas how I might make this work?
#include <AccelStepper.h>
#include <MultiStepper.h>
AccelStepper stepper1(1,8,9); // stepper1, Pulse Pin 8, Direction Pin 9
bool newData, runallowed = false;
char receivedCommand;
long CoordinateX = 0;
long CoordinateY = 0;
const byte endSwitchPin = 2; //pin for the end stop switch
pinMode(endSwitchPin, INPUT_PULLUP); //internal pullup resistor
attachInterrupt(digitalPinToInterrupt(endSwitchPin), stopMotor, FALLING); //When the endSwitchPin sees ground, it will interrup the progam with stopMotor()
Serial.begin(9600); //baud rate for serial monitor
Serial.println("Motor Position Testing"); //print this message on open
Serial.println("Positions available: 1-9"); // ^
stepper1.setMaxSpeed(1600); //Max speed steps/second
stepper1.setAcceleration(800); //Acceleration steps/second/second
stepper1.disableOutputs(); //Keeps outputs disabled when not in use
checkSerial(); //check for recieved commands on the serial monitor
runMotor(); //enables or disables motor outputs
void runMotor() //enables or disable motor outputs
if (runallowed == true)
stepper1.enableOutputs(); //enable output pins if run is allowed
stepper1.run();
stepper1.disableOutputs(); //disable output pins if run is not allowed
return;
void checkSerial() //check for recieved commands on the serial
if (Serial.available() > 0) //if something comes from the computer
receivedCommand = Serial.read(); // pass the value to the receivedCommand variable
newData = true; //indicate that there is a new data by setting this bool to true
if (newData == true) //we only enter this long switch-case statement if there is a new command from the computer
switch (receivedCommand) //we check what is the command
case '1': //Position 1 for the motors
Serial.println("Moving to Position 1"); //print text before moving
CoordinateX = 1000;
CoordinateY = 1000;
MovePosition(); //run the command for moving to a position
case '2': //Position 2 for the motors
Serial.println("Moving to Position 2"); //print text before moving
CoordinateX = 2000;
CoordinateY = 1000;
case '3': //Position 3 for the motors
Serial.println("Moving to Position 3"); //print text before moving
CoordinateX = 3000;
CoordinateY = 1000;
case '4': //Position 4 for the motors
Serial.println("Moving to Position 4"); //print text before moving
CoordinateX = 1000;
CoordinateY = 2000;
case '5': //Position 5 for the motors
Serial.println("Moving to Position 5"); //print text before moving
CoordinateX = 2000;
CoordinateY = 2000;
case '6': //Position 6 for the motors
Serial.println("Moving to Position 6"); //print text before moving
CoordinateX = 3000;
CoordinateY = 2000;
case '7': //Position 7 for the motors
Serial.println("Moving to Position 7"); //print text before moving
CoordinateX = 1000;
CoordinateY = 3000;
case '8': //Position 8 for the motors
Serial.println("Moving to Position 8"); //print text before moving
CoordinateX = 2000;
CoordinateY = 3000;
case '9': //Position 9 for the motors
Serial.println("Moving to Position 9"); //print text before moving
CoordinateX = 3000;
CoordinateY = 3000;
case '0': //Position Home for the motors
Serial.println("Moving to Home"); //print text before moving
CoordinateX = 0;
CoordinateY = 0;
default:
newData = false;
void MovePosition()
runallowed = true; //enable outputs
stepper1.moveTo(CoordinateX); //move large motor to coordinates defined in the serial cases
void stopMotor()//function activated by the pressed microswitch
runallowed = false; //disable running
stepper1.setCurrentPosition(0); // reset position
Serial.println("STOP "); //print action
stepper1.stop(); //stop motor
stepper1.disableOutputs(); //disable power
Thanks in advance!
