Some how it doesn end and I tried to and break; after "TEXT DONE" but it doesn't go to the loop part
Serial.println("MG2639 example");
pinMode(cellReset, OUTPUT);
digitalWrite(cellReset, LOW); //Don't reset
pinMode(cellOnOff, OUTPUT);
digitalWrite(cellOnOff, LOW); //Don't turn on at this time
pinMode(trigger, OUTPUT);
digitalWrite(trigger, LOW);
delay(5000);
if(!gpsMG2639()) //Se baud rates and bring module online
Serial.println("Module failed to respond. Hanging.");
setup();
Serial.println("Module online!");
//MG2639.print("AT+CREG=2\r");
//delay(100);
boolean textSent = false;
while(1)
int rssi = checkSignalStrength();
Serial.print("RSSI: ");
Serial.println(rssi, DEC);
checkRegistration();
delay(2000);
if(rssi < 40 && textSent == false)
textSent = true;
sendTextMessage("09292983237",parse);
digitalWrite(trigger, HIGH);
Serial.println("TEXT DONE");
Serial.println("DONE");
boolean gpsMG2639(void)
//Quick test to see if module is already on and responding to AT commands
MG2639.begin(9600);
for(int x = 0 ; x < 5 ; x++)
if(checkATOK()) return(true);
delay(100);
MG2639.end(); //That failed
Serial.println("Turning on module");
digitalWrite(cellOnOff, HIGH); //Turn on module
delay(3000);
digitalWrite(cellOnOff, LOW); //Leave module on
Serial.println("Module should now be on");
MG2639.begin(115200);
delay(10);
MG2639.print("AT+IPR=4800\r\n"); //Set baud rate to 9600bps
delay(10);
MG2639.end(); //Hang up and go to 9600bps
MG2639.begin(4800);
delay(10);
//Try sending AT 5 times before giving up
delay(100);
return(false);
