Ending/breaking loop
Hi!
I have two analog sensors hooked up to my arduino. I would like to do a program, which counts how many times the other sensor (pressure sensor) is pressed and at a certain stage of the other sensor. So if the other sensor (a potentiometer) stays untouched the counter goes on forewer, but if the potentiometer is touched and it gives a different output the counter is reseted.
I have managed the counter-part, but I can not figure out, if is possible somehow to reset the counter..So help is really appreciated, I guess this is a simple question for someone, who has more experience..I'm still a novice in these things :slight_smile:
Here is my code so far.. :
Serial.print("potentiometer state is : ");
int potentiometer=analogRead(A1);
Serial.println(potentiometer);
int counter=0;
int pressuresensor=analogRead(A0);
int reading = map (potentiometer, 1023,0,0,100);
while(potentiometer reading stays the same); //I don't know how to do this !!!
if(pressuresensor>0)
counter=counter+1;
Serial.print(counter);
Serial.print(" at ");
Serial.print(reading);
Well, to me, "potentiometer reading stays the same" means that the current reading is the same as the previous reading. This implies that you need a global or static variable to save the current reading in, at the end of loop(), as the previous reading.
Then, the while statement would look something like:
while(currReading == prevReading)
   // Do some stuff
   currReading = map (potentiometer, 1023,0,0,100);
prevReading = currReading;
unsigned int potentiometer; // value of potmeter reading
unsigned int pressuresensor; // value of pressure sensor reading
unsigned int reading;          // mapped potmeter value to range 1-100
unsigned int old_reading;     // old mapped value of potmeter
  // open serial
  // do initial reading of potentionmeter
  old_reading = map (potentiometer, 1023,0,0,100);
  // display value
  // initialize counter
  int counter=0;
  // read both sensor and potentiometer
  // check if potmeter has changed
  if (reading != old_reading) {
    // potmeter setting has changed so reset counter and
    // save reading
    old_reading = reading;
    counter = 0;
    // potmeters has not changed so test if pressure sensor needs
    // to be incremented
      // pressure sensor shows value > 0
      counter++;
something like this?
nicoverduin:
You tell us.
Hey,
thank you very much! It works just as I wanted :smiley:
I just added
unsigned int counter;
in the beginning and that was it :slight_smile: Why should the int:s be unsigned??
If not it will turn into a negative number as the most significant bit is interpeted as a sign. Defining it as unsigned means it will always be positive. if numbers are less than around 31000 it is no problem. But it is a matter of habit to make a number unsigned if it should not be negative.
And you are welcome :slight_smile:
nicoverduin:
less than 32768 to be precise.
Sorry I was to lazy to check it out :slight_smile:
