Endless loop
Hi, I am making an RGB strip that is controllable over wifi and that will go on when it is dark and go off when it is light. So I am trying to make an endless loop so that the Arduino will “scan” if it is light or dark and then automatically go on/off depending on the readings of the light resistor. Currently, I have it working that the light resistor will “scan” the light conditions and then make the RGB lights burn of not but this all has to be done manually and I want to make it automatically. So can someone please explain to me how I to do this.
This is the function I am talking about
void warm(uint8_t wait) {
  int sensorValue = analogRead(sensorPin);
  if (sensorValue < lowThreshold){
    for(int i=0;i<NUMPIXELS;i++){
    // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
    pixels.setPixelColor(i, pixels.Color(255,147,28)); // Moderately bright green color.
    pixels.show(); // This sends the updated pixel color to the hardware
    delay(delayval); // Delay for a period of time (in milliseconds).
    delay(100);}}
    pixels.setPixelColor(i, pixels.Color(0,0,0)); // Moderately bright green color.
    pixels.show(); // This sends the updated pixel color to the hardware.
    delay(100);
This is the full code
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#define PIN D4
#define NUMPIXELS      7
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip = Adafruit_NeoPixel(15, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 500; // delay for half a second
int sensorPin = 0;
int lightState = 0;
int lowThreshold = 200;
int highTreshold = 250;
const char* ssid = "SECRET";
const char* password = "SECRET";
ESP8266WebServer server(80);
const int led = 13;
void handleRoot() {
  server.send(200, "text/plain", "usage:\n/warm");
void handleNotFound(){
  digitalWrite(led, 1);
  String message = "File Not Found\n\n";
  message += "URI: ";
  message += server.uri();
  message += "\nMethod: ";
  message += (server.method() == HTTP_GET)?"GET":"POST";
  message += "\nArguments: ";
  message += server.args();
  message += "\n";
  for (uint8_t i=0; i<server.args(); i++){
    message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
  server.send(404, "text/plain", message);
  digitalWrite(led, 0);
    delay(100);}}
    delay(100);
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
void setup(void){
  pinMode(led, OUTPUT);
  WiFi.begin(ssid, password);
  Serial.println("");
  // Wait for connection
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  if (MDNS.begin("esp8266")) {
    Serial.println("MDNS responder started");
  server.on("/", handleRoot);
  server.on("/warm", [](){
    server.send(200, "text/plain", "warm");
    warm(20);
  server.onNotFound(handleNotFound);
  server.begin();
  Serial.println("HTTP server started");
    strip.begin();
  strip.show(); // Initialize all pixels to 'off'
void loop(void){
  server.handleClient();
I am trying to make an endless loop so that the Arduino will "scan" if it is light or dark and then automatically go on/off depending on the readings of the light resistor
You mean something like the loop() function ?
Try to put a call to "void warm(..)" in "void loop()". And try to avoid cut'n paste "programming" ;)
What part does the ESP8266 play in the operation of this project ?
I am using a wemos d1 mini basically an Arduino with an esp8266 built in. The esp8266 creates a local server and I can access that by an IP address that is printed in the serial monitor. So if I connect to the local server then I can type /warm and then the RGB strip will go on if there is not enough light.
If I replace the void warm to void loop than "warm" is not declared in code before that.
Making a call to a method does not mean to copy the method into another method :-/
Kawouterplop: I am using a wemos d1 mini basically an Arduino with an esp8266 built in. The esp8266 creates a local server and I can access that by an IP address that is printed in the serial monitor. So if I connect to the local server then I can type /warm and then the RGB strip will go on if there is not enough light.
OK, I get that. What do you want it to do instead ?
UKHeliBob: OK, I get that. What do you want it to do instead ?
He wants to put a call to "warm" inside "loop", but apparently he does not know (how to do) it ;)
Do you want to remove the web server functionality and just have the strip work when the light level is above (or below) a specified level ? What do you want to happen when it is light and when it is dark ?
