hello
im trying to start digital output on and off by sequence, and there will be a time delay in between, thats easy to do, but there is a condition for the sequence to start, digital inputs must be enebled, and when these inputs are off the sequence must stop and do other things, for example printing alarm on a LCD, her is the sequence:
if (DI1 is HIGH and DI2 is HIGH) {
DO1 is HIGH
delay (time)
DO2 is HIGH
delay(time)
else {
DO1 is LOW
DO2 is LOW
the problem is i want the sequence to stop directly if one of the inputs is off, is there away to use millis() to set a timer being trigred by action, and then start another timer, not only from the starting of arduino controller.
i tried to use some Libraries like simpletimer and timealarm, but the problem is that the timer is triggered from the starting of arduino controller, i need to use the timer at the logic of the program, any help will be appreciated.
thanks
