Any help is a good help! I appreciate you for spending some time on this!
Energy Meter: PZEM004T -100A
Arduino:UNO
SD Logger: Ver 1.0 clone with onboard DS1307 RTC
SD card: SD 16GB uSD class 10 A1 HC I
Comms:
SD-SPI
RTC-I2C
PZEM-Serial
Objective: To Measure the V, I, kW, kWh, hz and pf using the PZEM004T made available using the library:
Issue: Not able to use SD card over SPI and PZEM over Serial in the same code. Eventhough I am able to run them sepearately and they work fine. I get it, that there is a comm issue of the Serial but could not find a solution after days of systematic trial and errors. I had used software serial too for the PZEM but the issue persists. I had tried running on half SPI speed to but no good. I could use a Mega as given in
but I would like to get a solution with UNO as I had invested around 50 of UNO only for this project.
Note: The Libraries eat a lot of Mem too so the UNO displays the warning of stability.
