Engine Dynamometer project with interrupts
The following code is derived from a project in which my Arduino measures the RPM of a small DC motor up to 18,000 RPM. The Arduino also does PID calculations to keep the speed constant and receives instructions by wireless. Your Arduino will have no trouble reading the engine speed and the load cell. The code is not complete but it should give you the idea.
volatile unsigned long isrMicros;
unsigned long latestIsrMicros;
unsigned long previousIsrMicros;
volatile boolean newISR = false;
   if (newISR == true) {
     previousIsrMicros = latestIsrMicros; // save the old value
     noInterrupts(); // pause interrupts while we get the new value
        latestIsrMicros = isrMicros;
        newISR = false;
     interrupts();
     microsThisRev = latestIsrMicros - previousIsrMicos;
void myISR() {
   isrMicros = micros();
   newISR = true;
You should check to make sure the code for reading your load cell does not block the Arduino while it is waiting for the load cell to produce a reading.
...R
