Engine + Sensors
Hello,
In my project, I want to get on the serial monitor of the arduino IDE the data of two sensors (BMP280 and Sharp IR ) and in addition to make a servomotor turn.
The problem is that the motor turns correctly but I receive the data only once and not every second. I don't see where the error is in my program.
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_BMP280.h>
#include <Servo.h>
#define BMP_SCK (13)
#define BMP_MISO (12)
#define BMP_MOSI (11)
#define BMP_CS (10)
Servo myservo;
int pos = 0;
int Capteur_distance = A0;
Adafruit_BMP280 bmp; // I2C
myservo.attach(9);
Serial.println(F("BMP280 test"));
//if (!bmp.begin(BMP280_ADDRESS_ALT, BMP280_CHIPID)) {
if (!bmp.begin()) {
Serial.println(F("Could not find a valid BMP280 sensor, check wiring or "
"try a different address!"));
while (1) delay(10);
bmp.setSampling(Adafruit_BMP280::MODE_NORMAL,
Adafruit_BMP280::SAMPLING_X2,
Adafruit_BMP280::SAMPLING_X16,
Adafruit_BMP280::FILTER_X16,
Adafruit_BMP280::STANDBY_MS_500);
float volts = analogRead(Capteur_distance) * 0.0048828125;
int distance = 5 * pow (volts, -1);
Serial.print (distance);
Serial.print(",");
Serial.print(bmp.readTemperature());
Serial.print(",");
Serial.print(bmp.readPressure());
Serial.print(",");
Serial.print(bmp.readAltitude(1013.25)); /* Adjusted to local forecast! */
for (pos = 0; pos <= 90; pos += 1) {
// in steps of 1 degree
myservo.write(pos);
delay(200);
for (pos = 90; pos >= 0; pos -= 1) {
myservo.write(pos);
delay(200);
Thanks for your advice.
That for loop (and the other one) block execution for 18 seconds, each. So, yeah, getting data every second will be problematic.
Maybe investigate millis() non-blocking timing.
Non-blocking timing tutorials:
Blink without delay().
Beginner's guide to millis().
Several things at a time.
