Hello people...
I would like someone to help me:
My printer's X, Y, Z, and E0 axis motors only rotate in one direction, they only rotate in both directions when manually starting the EEPROM on the LCD panel, (Control> Start EEPROM), when disconnecting the USB port all motors turn in one direction only. How can I solve this? thank you very much
I can only guess but it sounds like the printer has failed. Be sure it works with another system. I can only guess as there is not enough details or code. This response is to help you get started in solving your problem, not solve it for you.
Good Luck & Have Fun!
Gil
