Enhanced Serial Monitor - Version 3.1.3 UPDATE
SXRguyinMA: This may be exactly what I'm looking for. I'm looking for a way to monitor 4 sensors (3 temp and one flow meter) and plot data to a graph. I'll have to play with this and see what I can come up with. Thanks!
I can send you a copy to try if you are interested.
Cheers Alan
robtillaart: Hi Alan,
Think it is a pity you do not provide a latest (BETA) version of your Serial tool, so please reconsider.
I have written several classes/libs for Arduino and posted them on the playground and for most of them there was little feedback too, especially after the first days. So I recognize your argument. Still by keeping providing the (almost) latest version I collected valuable feedback over time - yes, in small amounts with large intervals - But sometimes I get a thank you mail or I find a lib back in some university project, indicating there is more interest than on first sight.
I rest my case ;)
I'll send out individual copies to interested parties so I can keep an eye on it more easily then review the situation.
cheers Alan
fantastic work … where to download?
I developed this app for chrome idea very similar but less complete as your
http://www.dataino.it/help/document_tutorial.php?id=13
dataino: fantastic work .. where to download?
That looks very interesting.
I'll work on a build this week and some sample code and docs so its easy to get going and email it to those who have asked to have a look at it.
language with which you have developed?
dataino: language with which you have developed?
This is .NET
I'll add you to the posting list
Alan thanks for the direct link to download your application. Most impressed installed/run without any problems and the sample code shows its capabilities well. Alan I'm not up to speed yet with Processing but is this written in Processing and if not what program have you used. Have you thought of providing a method by which a user can call up modules like the charting from another sketch e.g. a Data Logger sketch calling your XY plotter.
Alan keep developing, I'm happy to assist with some beta testing if you like
Ray Bright
rbright: Alan thanks for the direct link to download your application. Most impressed installed/run without any problems and the sample code shows its capabilities well. Alan I'm not up to speed yet with Processing but is this written in Processing and if not what program have you used. Have you thought of providing a method by which a user can call up modules like the charting from another sketch e.g. a Data Logger sketch calling your XY plotter.
Ray Bright
It is written in .NET. I found Processing too hard to extend to a 'full' application. Not saying it can't be done but I don't have a background in Processing.
Can you explain what you would like? I'm not sure I understand "calling from another sketch". Currently from the Arduino you can send data to the serial monitor that invokes any of the visualizers, you don't have to use only one at a time. If you mean can a single message from the Arduino to the serial monitor can be forwarded onto other visualizers then I have toyed with the idea of writing an event driven mechanism I have been thinking about the following. A message arrives at a visualizer on the serial monitor and then some user supplied script on the serial monitor decides how to decode the message pack and invoke one or more other visualizers - a kind of simplistic programming. However I haven't had a need for it so no effort has gone into it.
Other things on the wish list are:
  • A visualizer that receives the data stream and performs simple transformation to make it suitable for spreadsheets etc
  • Filtering the Monitor/Copy output to selectively show messages of a particular type only
  • User defined visualizers from definition files allowing layout of controls (like dials and gauges, sliders and buttons, graphs etc)
  • Redirection of data via IPC mechanisms on the PC to 3rd party programs (possibly two way)
  • Data extraction from existing visualizers - eg the data that makes up the current on screen plot
  • Convenient screen grab mechanism for images from visualizer
  • Wii Nunchuk visualizer
  • Plugin code to allow user defined processing. Previously done with VBscript which was exceptionally powerful but was impossible to verify the user's code before running so presents some really difficult implementation issues.
  • Improvements to existing visualizers
  • Alternate sources of data in place of the serial stream
  • Visualizers for popular algorithms such PID controlller, Complimentary filters, etc so tuning of parameters can be done via the serial monitor tool
  • Coming up with a good name for the tool...
  • ... and who knows what! Always interested to hear people's ideas but ideally trying to keep as an 'easy to use' type of tool yet gives a good amount of functionality for the effort.
JohnGeddes: Sorry if I have missed something, but what is the current status of this? It sounds brilliant, but the only link I can find has a warning above it saying not to download it. Is there a stable version yet: if so, where would I find it?
There is a version for trial available now. Let me know your email address and I'll send you a link.
You XY plotting works well. For people following this post the supplied demo code uses serial strings like #plotsweep~-177.4400~177.00~88.00~44.00~35.00 to represent 5 current analog values which are then plotted and replotted as each #plotsweep string is received. All great stuff.
From an arduino programming perspective you would need to build the serial character string as you read the analog inputs or any calculated variables which would be integers. Obviously character strings may need to be built up from integers so the itoa function will be required maybe in format itoa (analog1,analog1_txt,10). The raw Analog would be stored into an array before processing.
Alan I like your future consideration of " User defined visualizers from definition files allowing layout of controls (like dials and gauges, sliders and buttons, graphs etc)"
Regards all
rbright: You XY plotting works well. For people following this post the supplied demo code uses serial strings like #plotsweep~-177.4400~177.00~88.00~44.00~35.00 to represent 5 current analog values which are then plotted and replotted as each #plotsweep string is received. All great stuff.
Regards all
The sample code shows how to build up the strings, a helper function to do it for you and also includes a super useful function for dealing with floats which can be a real pain in the Ar...
Exactly what I am looking for. I am trying to monitor the output of 6 potentiometers in real time. Would love to try out your tool and leave a feedback. Please mail me the same. Thanks and appreciate your time and effort!
gsram89: Exactly what I am looking for. I am trying to monitor the output of 6 potentiometers in real time. Would love to try out your tool and leave a feedback. Please mail me the same. Thanks and appreciate your time and effort!
Done
Can I also have a chance to try out this plotting tool.
Regards Jorgen
You have mail.
dkjbl: Can I also have a chance to try out this plotting tool.
Regards Jorgen
I would like to try the tool.
Thanks
Wreckerone: Hi,
Thanks
You have mail
Nice looking I would like to try it.
Donny
I would also like to try this. It will help me tweak the sketch I'm using on my wheelchair based robot. The ability to call an external program will be VERY helpful. It looks fantastic! Thank you for sharing your work.
John
