Ensuring that my return values keep returning to the variables
#include <Servo.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
Servo myservoE;
int elevator = 40;
int CodeIn, elevatormovement;
myservoE.attach(3);
pinMode(13,OUTPUT);
elevator = constrain (elevator, 0,100);
myservoE.write(elevator);
if (Serial.available() > 0)
CodeIn=getChar();
if (CodeIn == '<')
lcd.print(
int returnValue= LESSTHAN();
if (returnValue == 1)
elevator ++;
else if (returnValue ==0)
elevator --;
char getChar()// The serial buffer routine to get a character
while(Serial.available() == 0);// wait for data
return((char)Serial.read());// Thanks Doug
}// end of getchar Roputine.
int LESSTHAN()
CodeIn=getChar();
switch (CodeIn)
case 'Q':
delay(11);
elevatormovement += char (Serial.read());
if (elevatormovement == '-') //pitch up
digitalWrite (13, HIGH);
return 1;
else if (elevatormovement == '+')//pitch down
digitalWrite(13,LOW);
return 0;
How do I allow continues feedback/return value ? The return value only sends out once and stops.
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the "Code" icon above the posting area. It is the first icon, with the symbol: </>
Why are you adding the read character to elevatormovement?
Separate the code for receiving data from the code for controlling your servo. That way you can test each part on its own. The code in loop() could be as simple as
   receiveData();
   updateServoPosition();
The examples in serial input basics are simple and reliable.
...R
Hi Guys,
Appreciated all the feedback given, as i am new to Arduino. I am trying to store the first character received by the serial port to elevatormovevement. This character would be either a + or - . After receiving the char (+ or - ) i would return a 1 or 0 accordingly. So with the return value either 1 or 0 . i would compare it with an int variable (returnValue) and it should turn the servo accordingly. However the problem i am facing now is that it only return the first char and it stops return the rest. Is there anyway to ensure that the returning of 0 and 1 is continuous and do not stop at the first return?
Thanks helping!
As Nick pointed out, the problem is that you're adding it to that variable... which is of integer type....
So the first time you get a + or -, it works, because the variable starts out as 0. The second time, however, since it starts with the old value, and you add the value of the received character to it, it's a value that's neither '+' nor '-'.
If you change the += to = it should work.
Thanks DrAzzy for the reply!
So my mistake was that i did not cleared my first value of the first time? How does changing the += to = helps in clearing the first value of the first time ?
Well, if you have a basket, and you add an apple to it. How many apples do you have? One. Now you add another one. How many now? Two?
But if you say "replace the contents of the basket with this apple" you will still only have one apple afterwards.
ilarduino:
How should i store all 5 values into 1 variable so that i can use the variable for comparing?
Did you study serial input basics that I linked to in Reply #3. If I understand what you are thinking I believe it is covered.
...R
