Entering 2 Passwords in a single system for 1 and 2 digit
Hello all,
                I am having a code for password operated digital  lock with 4x4 keypad.
I modified it as per my application to make an output LED High for single digit password say "1"
in a desired amount of time for On and OFF state
Now i want to enter another password with 2 digit say "11" to glow the LED for a different ON & OFF time (other than previous case).
The 2 password entry options should be on the same program & same keyboard but individually working and not interfering each other
Please check the code as only the single digit "1" is working but not allowing "11" to get on work.
So how to solve it ?
#include <LCD_I2C.h>
// Include Keypad library
#include <Keypad.h>
#include <SoftwareSerial.h>
#include "DFRobotDFPlayerMini.h"
//const int pin1 = LOW;
//int pin1State=0;
//bool pinState = LOW;
#define Num_Length 2
#define Num_Length1 3
int signalPin = 12;
char Data[Num_Length];
char Master[Num_Length] = "1";
char Data1[Num_Length1];
char Master1[Num_Length1] = "11";
char customKey;
byte data_count = 0, master_count = 0;
byte data_count1 = 0, master_count1 = 0;
// Constants for row and column sizes
const byte ROWS = 4;
const byte COLS = 4;
// Array to represent keys on keypad
char hexaKeys[ROWS][COLS] = {
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
// Connections to Arduino
byte rowPins[ROWS] = {9, 8, 7, 6};
byte colPins[COLS] = {5, 4, 3, 2};
// Create keypad object
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
// Create LCD object
LCD_I2C lcd(0x27, 16, 2);
SoftwareSerial mySoftwareSerial(10, 11); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
byte pbRegister = 0;
void setup(){
  mySoftwareSerial.begin(9600);
  if (!myDFPlayer.begin(mySoftwareSerial)) {  //Use softwareSerial to communicate with mp3.
    while(true){
      delay(0); // Code to compatible with ESP8266 watch dog.
  myDFPlayer.volume(29);
  myDFPlayer.playFolder(2, 2);
  lcd.begin();
  lcd.backlight();
  pinMode(signalPin, OUTPUT);
void loop(){
  // Get key value if pressed
  char customKey = customKeypad.getKey();
  if (customKey)
    Data[data_count] = customKey;
    lcd.setCursor(data_count,1);
    lcd.print(Data[data_count]);
    data_count++;
     if(data_count == Num_Length-1)
      lcd.clear();
      //clearData();
      switch(data_count)
    case 1:
    if(!strcmp(Data, Master)){
      lcd.print("Correct");
      digitalWrite(signalPin, HIGH);
    else{
      lcd.setCursor(0,0);
      lcd.print("incorrect");
      lcd.setCursor(0,1);
      lcd.print("InValid Entry");
      delay(2000);
      clearData();
     }  //switch end
        //lcd.clear();
     } //if(data_count == Num_Length-1)
          pbRegister = 0;
          delay(100);
      if (customKey)
    Data1[data_count1] = customKey;
    lcd.setCursor(data_count1,1);
    lcd.print(Data1[data_count1]);
    data_count1++;
      if(data_count1 == Num_Length1-1)
      lcd.clear();
      //clearData();
    switch(data_count1)
    case 2:
    if(!strcmp(Data1, Master1)){
      lcd.setCursor(3,0);
      lcd.print("all good");
      lcd.setCursor(3,1);
      lcd.print("opened");
      delay(5000);
    else{
      lcd.setCursor(0,0);
      lcd.print("go back");
      lcd.setCursor(0,1);
      delay(7000);
      clearData();
     }  //switch end
        //lcd.clear();
   }                        // void loop()
      void clearData()
        while(data_count !=0)
        Data[data_count--] = 0;
        while(data_count1 !=0)
        Data1[data_count1--] = 0;
      return;
Please help me out !! Thanksssss . . .
despite of in/correctness of first password the program goes further and make check for second password without to read new keys
I see . . so what to do for it's solution ??
What changes i need to make or what things needs to get added in code ?
Please help !!!
i am not clear with that what you want with LED. I understand you should have a keypad where 2 different passwords to type are, why not one password with 3 symbols.
Okk let me clear it first !
I have keypad and everything needed
Now suppose key pad is connected from 2 to 9 , then remaining pins can be used as output pin say 10, 11, 12 . .
Now Suppose, lets take a simple example of a door with 3 electro-mechanical locks and all the three should be opened with their individual passwords assigned and are activated with 10, 11, 12 output respectively for lock 1 lock 2 lock 3
I don't want to keep all the pass code same for security reasons and decided to make it like
1, 11 & 111 for lock 1 , lock2 lock 3 . .
Its just an example not the real motive actually
My basic aim is to assign any of the pass codes from a single digit to 2 and 3 digit individually operated one
So in that case i can assign it like
3, 48 & 221 or anything like that, just independent of having any limit for a set of digit
So how to go for that ??
Just let me know about only 2 cases say 1 and 11 for now . . that's it !!!
Ok sir le me go through this and check it out !!
Thanks !
Sir this code is not working any of the way
by pressing 1, it just display 1 at the second line
By pressing 11 the screen goes off blank
Its the result I'hv got
change any Serial outputs to proper LCD outputs and delays
#include <Wire.h>
#include <Keypad.h>
#define Num_Rings 2
String Data = "";
String Master[Num_Rings] = {"10", "230"};
char Key = 0;
byte Pass = 0;
const byte signalPin = 12;
const char hexaKeys[ROWS][COLS] = {
Keypad KPD = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
LiquidCrystal_I2C lcd(0x27, 16, 2);
    if (!myDFPlayer.begin(mySoftwareSerial))while (true);
    lcd.init();
    lcd.backlight();
  char Key = KPD.getKey();
  if (Key != NO_KEY) {
    Data += Key;
    Serial.print(Key);
    Key = 0;
    if (Data.length() == Master[Pass].length()) {
      if (Data == Master[Pass]) {
        Serial.println("Correct");
        Data = "";
        Pass ++;
        if (Num_Rings == Pass) {
          Serial.println("Opened");
        Pass = 0;
      else {
        Serial.println("incorrect");
        Pass = 0;
      Data = "";
  pbRegister = 0;
  delay(100);
}                        // void loop()
Ya Sir all the way i did with this code
But nothing is going to get happen
No display out !
did you made this?
Where exactly i need to do this Sir ??
serialBegin () ????????
open serial monitor and press 1, 0, 2, 3, 0
Ya it shows nothing
And by pressing other buttons, it sometimes display any of the key and sometimes not
and depending on that combination it displays incorrect
93 62 etc etc on random press
but with 1 0 2 3 0 it shows nothing
I am trying more n more
Ya i just do a waiting operation
pressed 1 and displayed 1 . . . then after waiting sometime I keep pressing 0 so many times and finally it placed 0 just after 1 and displayed Correct
Then same thing i did for 230 pressing so many times
It displayed
Correct
Opened
That way its working
Have to wait for a long time after a button press
or
have to press a button so so many times or sometimes in 2 3 press only
connected LED out to digital write and its working fine that way
//#include <Wire.h>
#include <Keypad.h>
#define Num_Rings 2
String Data = "";
char Key = 0;
byte Pass = 0;
    lcd.begin();
    lcd.backlight();
    Data += Key;
    Serial.print(Key);
    Key = 0;
        delay(3000);
        digitalWrite(signalPin, LOW);
        Data = "";
        Pass ++;
        Pass = 0;
      else {
        Pass = 0;
      Data = "";
  pbRegister = 0;
}                        // void loop()
But display is still not working Sir
How to solve that ??????
Sir one thing we missed that don't have the content under LCD.print to display
Not even a single line beginning note . .
Then we have nothing left here to display any operation's output
every where Serial.println() is you change back to lcd.print() . do not forget lcd.setcursor. copy from old sketch
Ya Sir did some changes and after practicals this code is displaying things but a four line 2 digit is displaying after word correct like this below
and rest issues are same like , have to press so many times and all that
//#include <Wire.h>
#include <Keypad.h>
#define Num_Rings 2
String Data = "";
char Key = 0;
byte Pass = 0;
    lcd.begin();
    lcd.backlight();
   //lcd.setCursor(0,0);
        //lcd.println("Enter Key - ");
    Data += Key;
    Serial.print(Key);
    lcd.print(Key);
    Key = 0;
      //lcd.println();
        lcd.setCursor(4,1);
        lcd.println("Correct");
        delay(3000);
        Data = "";
        Pass ++;
          lcd.println("Opened");
        Pass = 0;
      else {
        lcd.println("inCorrect");
        Pass = 0;
      Data = "";
      //lcd.println();
  pbRegister = 0;
}                        // void loop()
Displaying things are too going complicated and everytime the system needs reset for a proper output on screen
#include <Keypad.h>
#define Num_Rings 2
String Data = "";
char Key = 0;
byte Pass = 0;
  lcd.begin();
  lcd.backlight();
    Data += Key;
    lcd.setCursor(0, 1);
    lcd.print(Data);
    Key = 0;
      lcd.clear();
        Data = "";
        Pass ++;
          lcd.setCursor(3, 0);
          lcd.setCursor(3, 1);
          delay(5000);
      lcd.clear();
          Pass = 0;
      else {
        lcd.setCursor(0, 0);
        delay(7000);
      lcd.clear();
        Pass = 0;
      Data = "";
  delay(100);
Ya sir its working in one go but the system execute once !!
After that it just takes data one by one and then displays number and alphabet.
Either we need to reset Arduino or have to enter wrong code to reach the initial point of void loop
Then only again the system is available to enter the code and to operate further !!!
