enum member of a class
Is it correct to declare enumerator this way as a class member?
enum valvestate {open, closed, opening, closing, unknown};
class valve
public:
	valve();
protected:
private:
	valvestate _state;
and initialize using constructor
valve::valve()
    _state = opening;
compilation goes fine, but program doesn't work as expected. Seems like _state is not initialized.
Thanks ahead.
That is correct, but the valvestate enum is not a class member. It is outside the class, so it is global. The _state member is declared correctly.
You have some code you'd like us to look at, and some proof of your assertion?
Raptor5:
Yes it is - it's initialised right there in the constructor. :~
Raptor5:
class valve
public:
valve();
protected:
private:
valvestate _state;
valve::valve()
    _state = opening;
Thanks ahead.
It's correct, but you don't want to have an enum like that. It means that no other variable can be named any of those, and "open" is a variable upon which you cannot rely on users not using. Make the enum declaration a public member of the class.
For non-static members of a class, this is not initialising, its assigning.
valve::valve()
    _state = opening;
This is initialising:
valve::valve() : _state( opening )
{ return; }
