enum var error
Hj,
  • Firmware for the ”2WD Ultrasonic Motor Robot Car Kit”
Stephen A. Edwards
Hardware configuration :
  • A pair of DC motors driven by an L298N H bridge motor driver
  • An HC−SR04 ultrasonic range sensor mounted atop a small hobby servo
    #include <Servo.h>
    Servo servo;
// Ultrasonic Module pins
const int trigPin = 13; // 10 microsecond high pulse causes chirp , wait 50 us
const int echoPin = 12; // Width of high pulse indicates distance
// Servo motor that aims ultrasonic sensor .
const int servoPin = 11; // PWM output for hobby servo
// Motor control pins: L298N H bridge
const int enAPin = 6; // Left motor PWM speed control
const int in1Pin = 7; // Left motor Direction 1
const int in2Pin = 5; // Left motor Direction 2
const int in3Pin = 4; // Right motor Direction 1
const int in4Pin = 2; // Right motor Direction 2
const int enBPin = 3; // Right motor PWM speed control
enum Motor{LEFT,RIGHT};
// Set motor speed: 255 full ahead, −255 full reverse , 0 stop
void go( enum Motor m, int speed)
digitalWrite (m == LEFT ? in1Pin : in3Pin , speed > 0 ? HIGH : LOW );
digitalWrite (m == LEFT ? in2Pin : in4Pin , speed <= 0 ? HIGH : LOW );
analogWrite(m == LEFT ? enAPin : enBPin, speed < 0 ? -speed : speed );
// Initial motor test :
// left motor forward then back
// right motor forward then back
void testMotors()
static int speed[8] = {128, 255, 128, 0,
-128, -255, -128, 0};
go(RIGHT, 0);
for (unsigned char i = 0 ; i < 8 ; i++)
go(LEFT, speed[i ]), delay (200);
go(RIGHT, speed*), delay (200);*
// Read distance from the ultrasonic sensor , return distance in mm
// Speed of sound in dry air , 20C is 343 m/s
// pulseIn returns time in microseconds (10ˆ−6)
// 2d = p * 10ˆ−6 s * 343 m/s = p * 0.00343 m = p * 0.343 mm/us
unsigned int readDistance()
  • digitalWrite(trigPin,HIGH);*
  • delayMicroseconds(10);*
  • digitalWrite(trigPin,LOW);*
  • unsigned long period = pulseIn(echoPin,HIGH);*
    _ return period * 343 / 2000;_
    #define NUM_ANGLES 7
    unsigned char sensorAngle[NUM_ANGLES] = { 60, 70, 80, 90, 100, 110, 120 };
    unsigned int distance[NUM_ANGLES];
    // Scan the area ahead by sweeping the ultrasonic sensor left and right
    // and recording the distance observed. This takes a reading , then
    // sends the servo to the next angle. Call repeatedly once every 50 ms or so.
    void readNextDistance()
  • static unsigned char angleIndex = 0;*
  • static signed char step = 1;*
  • distance[angleIndex] = readDistance();*
  • angleIndex += step ;*
  • if (angleIndex == NUM_ANGLES -1) step = -1;*
  • else if (angleIndex == 0) step = 1;*
  • servo.write(sensorAngle[angleIndex]);*
    // Initial configuration
    // Configure the input and output pins
    // Center the servo
    // Turn off the motors
    // Test the motors
    // Scan the surroundings once
    void setup () {
    pinMode(trigPin , OUTPUT);
    pinMode(echoPin, INPUT);
    digitalWrite ( trigPin , LOW);
    pinMode(enAPin, OUTPUT);
    pinMode(in1Pin, OUTPUT);
    pinMode(in2Pin, OUTPUT);
    pinMode(in3Pin, OUTPUT);
    pinMode(in4Pin, OUTPUT);
    pinMode(enBPin, OUTPUT);
    servo . attach (servoPin );
    servo . write (90);
    go(LEFT, 0);
    go(RIGHT, 0);
    testMotors ();
    // Scan the surroundings before starting
    servo . write ( sensorAngle[0] );
    delay (200);
    for (unsigned char i = 0 ; i < NUM_ANGLES ; i ++)
    readNextDistance (), delay (200);
    // Main loop:
    // Get the next sensor reading
    // If anything appears to be too close , back up
    // Otherwise, go forward
  • readNextDistance();*
  • // See if something is too close at any angle*
  • unsigned char tooClose = 0;*
  • for (unsigned char i = 0 ; i < NUM_ANGLES;i++)*
    _ if (distance < 300)_
    * tooClose = 1;*
    * if (tooClose) {*
    * // Something’s nearby: back up left*
    * go(LEFT, -180);*
    * go(RIGHT, -80);*
    * } else {*
    * // Nothing in our way: go forward*
    * go(LEFT, 255);*
    * go(RIGHT, 255);*
    * // Check the next direction in 50 ms*
    * delay (50);*
    [/quote]
    this is my script but when i compile under linux mint tara with arduino it shows this error: (in german)
    car.ino:12:15: Fehler: Verwendung des enum »Motor« ohne vorherige Deklaration
    but when i compile under windows 10 , it woks fine.
    its an uno
    pls help
This
should be
void go( byte m, int speed)
Which version of the Arduino IDE is installed on your Linux computer?
lesept:
This
should be
I think it's best to do this:
void go(Motor m, int speed)
The benefit of using the Motor type is that if you pass the function a value not defined in the enum, you get a helpful warning:
C:\Users\per\AppData\Local\Temp\arduino_modified_sketch_501586\sketch_dec06b.ino:44:10: warning: invalid conversion from 'int' to 'Motor' [-fpermissive]
   go(42, 0);
C:\Users\per\AppData\Local\Temp\arduino_modified_sketch_501586\sketch_dec06b.ino:30:6: note:   initializing argument 1 of 'void go(Motor, int)'
