Buenos Dias, estoy necesitando hacer un modulo capaz de tomar por HTTP REQUEST, el numero de telefono y el mensaje para que sea enviado.
La consulta al servidor se debe hacer cada 15 segundos, y si es que tiene nuevos mensajes, que los mismo sean enviados a sus destinatarios correspondientes.
Tengo un arduino uno conectado con el ethernet Shield w5100 y un Sim800l para envio de mensajes.
Estoy utilizando el Codigo de Ejemplo de la libreria ETHERNET que viene en arduino por defecto:
Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe, based on work by Adrian McEwen
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server[] = "www.google.com"; // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 0, 177);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, ip);
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET /search?q=arduino HTTP/1.1");
client.println("Host: www.google.com");
client.println("Connection: close");
client.println();
// if you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
while (true);
Y la respuesta que obtengo por el puerto serie es la siguiente:
connecting...
connected
HTTP/1.1 200 OK
Date: Wed, 20 Sep 2017 15:36:30 GMT
Server: Apache/2.2.15 (CentOS)
X-Powered-By: PHP/5.5.34
Connection: close
Transfer-Encoding: chunked
Content-Type: text/html; charset=UTF-8
21
>>>>69989968@Probando mensaje<<<<
0
disconnecting.
En vez de www.google.com utilizo la pagina del servidor, pero es de un cliente y no puedo mostrarlo.
A partir de donde dice: ">>>>69989968@Probando mensaje<<<<" tengo que guardar en una variable el numero de telefono, y en la otra el mensaje asi luego puedo enviarlas por mensaje
el mensaje lo envio con el siguiente codigo:
void EnviarSMS(){
Serial.println ("Enviando Mensaje...");
delay (2000);
mySerial.println("AT+CMGF=1"); // Activamos la funcion de envio de SMS
delay(100); // Pequeña pausa
mySerial.println("AT+CMGS=\"NumeroTel\""); // Definimos el numero del destinatario en formato internacional
mySerial.print(Mensaje);
delay(500); // Pequeña pausa
mySerial.print(char(26)); // Enviamos el equivalente a Control+Z
mySerial.println(""); // Enviamos un fin de linea
delay(5000);
mySerial.end();
delay (1000);
En donde necesito ayuda es en guardar los datos del request en las dos variables y luego enviarlas por sms. Que cada 15 segundo revise si tiene mensaje que enviar y lo envie.
Saludos, y espero con ansias sus Ayudas.
P.D: Es mi Primer Posteo.
