Envoi commande 32 bits chacon avec shield ethernet
Bonjour,
Je débute avec Arduino, j'aimerais pouvoir être aiguillé sur ce projet:
Je cherche à contrôler des prises électriques Chacon Ref avec ma carte arduino uno/Kit de transmission 433MHz + shield ethernet.
J'ai réussi à réceptionner les codes ON/OFF de ma télécommande avec un exemple de la librairie HomeEasy.
Et avec ce code je peux allumer et éteindre une lampe.
 * HE300 Automatic Protocol Transmitter 'Simulator'
 * This demo code emits a homeeasy automatic protocol ON message
 * then 3 seconds later, an off message
 * You dont need to learn the Arduino into the socket, because it can
 * pretend to be a transmitter you already have.
 * Use the Automatic protocol reciever code above to find out
 * your transmitter address 8-)
 * *Only* tested with one HE300 transmitter (HE Address 272946) with its
 * slider switch set to 1 which appears to be 0 in fact.
 * Seems to work with a switch socket (HE302S) and can turn it on and off
 * without the ardunio being learned into the socket.
 * Martyn Henderson 02/10/2009  http://martgadget.blogspot.com
 * Cheers to Barnaby and Peter, because without the code above
 * that shows the receiver output this wouldnt have been possible!
 * If you make something cool using HomeEasy and Arduino, please
 * post back here with a link to your code so we can all enjoy.
bool bit2[26]={};              // 26 bit global to store the HE device address.
int txPin = 2;                 // 433mhz transmitter on pin2
  pinMode(txPin, OUTPUT);      // transmitter pin.
  Serial.begin(9600);         // console port
  Serial.println("go");
  itob(11833462,26);            // convert our device code..
  transmit(true);            // send ON
  delay(10);                 // wait (socket ignores us it appears unless we do this)
  transmit(true);            // send ON again
  delay(3000);               // wait 3 sec
  transmit(false);           // and off again.
  delay(10);
  transmit(false);
  Serial.println("stop");    // done.
  // we dont use the arduino loop, this is a one-shot transmit in this example.
void transmit(int blnOn)
  int i;
  // Do the latch sequence..
  digitalWrite(txPin, HIGH);
  delayMicroseconds(275);     // bit of radio shouting before we start.
  digitalWrite(txPin, LOW);
  delayMicroseconds(9900);     // low for 9900 for latch 1
  digitalWrite(txPin, HIGH);   // high again
  delayMicroseconds(275);      // wait a moment 275
  digitalWrite(txPin, LOW);    // low again for 2675 - latch 2.
  delayMicroseconds(2675);
  // End on a high
  // Send HE Device Address..
  // e.g. 1000010101000110010  272946 in binary.
  for(i=0; i<26;i++)
    sendPair(bit2[i]);
  // Send 26th bit - group 1/0
  sendPair(false);
  // Send 27th bit - on/off 1/0
  sendPair(blnOn);
  // last 4 bits - recipient   -- button 1 on the HE300 set to
  // slider position I in this example:
  sendPair(false);
  sendPair(false);
  sendPair(false);
  sendPair(false);
  digitalWrite(txPin, HIGH);   // high again (shut up)
void sendBit(boolean b) {
  if (b) {
    delayMicroseconds(310);   //275 orinally, but tweaked.
    delayMicroseconds(1340);  //1225 orinally, but tweaked.
  else {
void sendPair(boolean b) {
  // Send the Manchester Encoded data 01 or 10, never 11 or 00
  if(b)
    sendBit(true);
    sendBit(false);
  sendBit(false);
  sendBit(true);
void itob(unsigned long integer, int length)
{  //needs bit2[length]
  // Convert long device code into binary (stores in global bit2 array.)
 for (int i=0; i<length; i++){
   if ((integer / power2(length-1-i))==1){
     integer-=power2(length-1-i);
     bit2[i]=1;
   else bit2[i]=0;
unsigned long power2(int power){    //gives 2 to the (power)
 unsigned long integer=1;
 for (int i=0; i<power; i++){
   integer*=2;
 return integer;
Maintenant, je voudrais pouvoir envoyer les codes 0N/OFF depuis une page web ou une application Android. Mais je n'arrive pas à comprendre comment faire...
Actuellement, pour éteindre ou allumer la lampe 2 par exemple, je change dans le programme la partie des 4 derniers digits en mettant 0010 FFTF. Ca marche mais comment faire pour piloter 6 boutons sans devoir changer le code à chaque fois?
Comment envoyer la commande par URL? ou encore mieux depuis une application Android directement? J'ai téléchargé l'apps DomoticHome et Arduino Control Pro mais je n'arrive pas à configurer les boutons.
J'ai regardé d'autres projets similaires mais soit cette partie n'est pas traitée soit je ne comprends pas...
Si quelqu'un pouvait m'orienter dans mes recherches?
Merci
Salut a toi,
Je vais essayer de t'orienter dans tes recherches. je ne suis pas un expert dans le domaine mais tout comme toi j'essai de développer ma solution domotique et de faire communiquer via RF des composants arduino ou raspberry afin de controler a distance volets lampes etc.
Pour envoyer des commandes d'une page web via arduino je n'ai jamais fait. Je sais faire via raspberry. Facile car le RPI est un serveur web également.
Mais avec ton shield ethernet ca doit être plus ou moins similaire. Comme tu peux acceder a ton arduino via reseau local, rien ne t'empêche depuis une page web d'envoyer une commande via un script pyhton par ex) vers l'arduino qui l'interpretera et excutera une action en fonction de la commande envoyée.
Tu peux jeter un oeil ici ou on explique le simple allumage d'une led via un script python qui envoi une commande sur l'arduino:
Concernant une appli android je ne sais pas du tout. Tu peux toujours faire ta propre appli (mais bon courage!). Sinon tu te montes un serveur web accessible de l'extérieur et tu t'y connecte via ton ptb.
J'ai a mon tour une question. Le code on/off que tu envoi c'est bien ceci:
itob(11833462,26);
Mais cela dépend de ta télécommande? je suppose que pour la mienne le code est différent?
Salut,
Le plus simple est d'herberger une interface en html sur ta carte arduino ... Regarde l'exemple ethernet server.
Ensuite sur ta page tu affiches 6 boutons (regarde les formulaires avec la méthode GET), avec 6 noms différents (un pour chaque prise) ... Dans ton programme arduino, tu décodes les infos envoyées par la page html (c'est le nom des boutons qui est récupéré...) et suivant le cas, tu envoies l'ordre qui va bien ...
Dans cet exemple GitHub - sui77/rc-switch: Arduino lib to operate 433/315Mhz devices like power outlet sockets., l'auteur peut commander RCswitchs via une interface HTML ... C'est quasiment ce que tu cherches !
la fonction void httpResponseHome(Client c) affiche une interface html, et les lignes 74 75 et 78 79 sont les lignes actives, celle qui vont envoyer des infos au serveur quand tu cliqueras dessus... Observe bien les codes qui suivent les ?
La fonction void processCommand(char* command) traite les infos que reçoit le serveur quand tu cliques sur les liens actifs ... Suivant le cas (1-on 1-off 2-on 2-off), il exécute ces commandes On Off sur son switch 1 ou 2...
A toi de jouer, tu n'as plus qu'à adapter ce code à ton projet
