Bonjour,
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#define LMIC_DEBUG_LEVEL 2
const int trigPin = 3;
const int echoPin = 4;
float duration, distance;
static const u1_t PROGMEM DEVEUI[8] = {0xfb, 0x78, 0x37, 0xc7, 0x83, 0x24, 0x81, 0x5f};
void os_getDevEui (u1_t* buf) {
memcpy_P(buf, DEVEUI, 8);
// Change this!
static const u1_t PROGMEM APPKEY[16] = {0x15, 0x50, 0x52, 0xf0, 0xe2, 0x7d, 0x72, 0xee, 0x74, 0xa8, 0x37, 0x13, 0x36, 0x71, 0xac, 0x91};
void os_getDevKey (u1_t* buf) {
memcpy_P(buf, APPKEY, 16);
static osjob_t sendjob;
// Schedule TX every this many seconds
const unsigned TX_INTERVAL = 20;
// Pin mapping
const lmic_pinmap lmic_pins = {
.nss = 10,
.rxtx = LMIC_UNUSED_PIN,
.rst = 9,
.dio = {2, 6, 7},
void onEvent (ev_t ev) {
Serial.print(os_getTime());
Serial.print(": ");
switch (ev) {
case EV_SCAN_TIMEOUT:
Serial.println(F("EV_SCAN_TIMEOUT"));
case EV_BEACON_FOUND:
Serial.println(F("EV_BEACON_FOUND"));
case EV_BEACON_MISSED:
Serial.println(F("EV_BEACON_MISSED"));
case EV_BEACON_TRACKED:
Serial.println(F("EV_BEACON_TRACKED"));
case EV_JOINING:
Serial.println(F("EV_JOINING"));
case EV_JOINED:
Serial.println(F("EV_JOINED"));
case EV_RFU1:
Serial.println(F("EV_RFU1"));
case EV_JOIN_FAILED:
Serial.println(F("EV_JOIN_FAILED"));
case EV_REJOIN_FAILED:
Serial.println(F("EV_REJOIN_FAILED"));
case EV_TXCOMPLETE:
Serial.println(F("EV_TXCOMPLETE (includes waiting for RX windows)"));
if (LMIC.dataLen) {
// data received in rx slot after tx
Serial.print(F("Data Received: "));
Serial.write(LMIC.frame + LMIC.dataBeg, LMIC.dataLen);
// Schedule next transmission
os_setTimedCallback(&sendjob, os_getTime() + sec2osticks(TX_INTERVAL), do_send);
case EV_LOST_TSYNC:
Serial.println(F("EV_LOST_TSYNC"));
case EV_RESET:
Serial.println(F("EV_RESET"));
case EV_RXCOMPLETE:
// data received in ping slot
Serial.println(F("EV_RXCOMPLETE"));
case EV_LINK_DEAD:
Serial.println(F("EV_LINK_DEAD"));
case EV_LINK_ALIVE:
Serial.println(F("EV_LINK_ALIVE"));
default:
Serial.println(F("Unknown event"));
byte buffer[52];
void do_send(osjob_t* j , int distance ) {
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
distance = (duration * 0.0343) / 2;
Serial.print("Distance: ");
Serial.println(distance);
if (LMIC.opmode & OP_TXRXPEND) {
Serial.println(F("OP_TXRXPEND, not sending"));
String message;
if (distance < 6) {
message = "Occupied";
message = "Not Occupied";
message.getBytes(buffer, message.length() + 1);
Serial.println("Sending: " + message);
LMIC_setTxData2(1, buffer, message.length(), 0);
Serial.println(F("Packet queued"));
// Next TX is scheduled after TX_COMPLETE event.
// Leave this empty
static const u1_t PROGMEM APPEUI[8] = {};
void os_getArtEui (u1_t* buf) {
memcpy_P(buf, APPEUI, 8);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
Serial.println(F("Starting"));
pinMode(LED_BUILTIN, OUTPUT);
#ifdef VCC_ENABLE
// For Pinoccio Scout boards
pinMode(VCC_ENABLE, OUTPUT);
digitalWrite(VCC_ENABLE, HIGH);
#endif
// LMIC init
os_init();
// Reset the MAC state. Session and pending data transfers will be discarded.
LMIC_reset();
LMIC_setClockError(MAX_CLOCK_ERROR * 1 / 100);
LMIC_setupChannel(0, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(1, 868300000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(2, 868500000, DR_RANGE_MAP(DR_SF12, DR_SF7B), BAND_CENTI); // g-band
LMIC_setupChannel(3, 867100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(4, 867300000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(5, 867500000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(6, 867700000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(7, 867900000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(8, 868800000, DR_RANGE_MAP(DR_FSK, DR_FSK), BAND_MILLI); // g2-band
// Disable link check validation
LMIC_setLinkCheckMode(0);
// LMIC_setDrTxpow(DR_SF7, 23);
// LMIC_setDrTxpow(DR_SF8, 23);
// LMIC_setDrTxpow(DR_SF9, 23);
// LMIC_setDrTxpow(DR_SF10, 23);
// LMIC_setDrTxpow(DR_SF11, 23);
// LMIC_setDrTxpow(DR_SF12, 23);
// Start job
do_send(&sendjob, distance );
os_runloop_once();
Si vous pouvez le constater,
String message;
if (distance < 6) {
dans cette partie du code, le message a envoyé est sous format de chaines de caracteres.
J'aimerais les envoyer sous format json, comment faire ?
