Good morning everyone, I have a problem with a lilygo t5 V.2.31 card with its epaper display.
I can't understand why, when I insert lines, even just text, into the loop, the card slows down considerably. when I go to print on the serial port, I am very slow, almost a second for each line, this is then reflected in the code that for simplicity I removed. Can anyone explain to me why without the loop part I have the printout at a few hundredths of a second and with a simple TEST writing on the loop the printout is almost a second?`
Thank you all and have a nice day.
#include <Arduino.h>
#include <GxEPD2_BW.h>
#include <U8g2_for_Adafruit_GFX.h>
#define SCREEN_WIDTH 122
#define SCREEN_HEIGHT 250
GxEPD2_BW<GxEPD2_213_BN, GxEPD2_213_BN::HEIGHT> display(GxEPD2_213_BN(/*CS=5*/ SS, /*DC=*/ 17, /*RST=*/ 16, /*BUSY=*/ 4)); // DEPG0213BN 122x250, SSD1680, TTGO T5 V2.4.1, V2.3.1
U8G2_FOR_ADAFRUIT_GFX u8g2Fonts;
display.init();
display.setTextColor(GxEPD_BLACK);
display.firstPage();
display.setRotation(3);
u8g2Fonts.begin(display);
uint16_t bg = GxEPD_WHITE;
uint16_t fg = GxEPD_BLACK;
u8g2Fonts.setForegroundColor(fg);
u8g2Fonts.setBackgroundColor(bg);
do {
display.fillScreen(GxEPD_WHITE);
u8g2Fonts.setFont(u8g2_font_ncenB18_te);
u8g2Fonts.setCursor(10, 40);
u8g2Fonts.print("T: ");
} while (display.nextPage());
display.hibernate();
// If I enable these lines I have a slowdown in calculations and serial output ///
u8g2Fonts.setCursor(40, 40);
// u8g2Fonts.print(altitude);
u8g2Fonts.print("test");
display.display(true); // partial update
Serial.println(" test ");
You may have hit a real issue with the GxEPD2_213_BN.cpp driver class.
This driver class is for the SSD1680 controller, and was last updated in Version 1.5.4.
This update is known for issues with SSD controllers.
One of the known issues was not present on this panel, as I can see on the result of the last test.
But the fix for this issue, and other fixes for SSD controllers have not been applied to this class.
If you provide your test-code in an updated style, I will test your issue and hopefully provide a fix. Make sure it is in a real code window (<code/> command symbol), not in a look alike that can't be copied.
I am constantly short on time, so I need complete information and easy reproduceable tests to analyze issues.
-jz-
