Hello
I want to build this robot (http://diyhacking.com/make-line-follower-10-minutes/#comment-1549) for my EPQ at college but the only problem is I don't want to be spending too much money. Basically in this diagram and project the guy uses continuous servos which are almost double to price of the other components so is there anyway I can use DC motors instead of Servos?
Thanks,
Ben
Sure.
Simply replace the servos with a DC motor and drive them from a H-bridge, then modify the software to drive the H-bridge and not the servo.
Saving money requires knowledge and effort.
Ok so which H Bridge do you recommend buying?
The IC SN754410 is a dual H-Bridge that I have used successfully in the past.
Hello can you give me a link to where I can buy them and how to wire them up?
Thanks again,
Ben
What good is that I don't know where you live?
Google the part number for a local supplier.
See the data sheet of the chip.
LOL I meant a link to purchase one online...
BenBilly05:
So you are in the U.S.A I assume so are you happy if I give you an link to get one from England?
http://uk.farnell.com/texas-instruments/sn754410neg4/ic-quadruple-half-h-driver-754410/dp/9592997?ost=SN754410&categoryId=700000004216
