EPROM Question
ive been playing with the arduino for a little under a month and im now onto my second project.
basically what i want to do is store a number in the eeprom, and every time i power up the arduino i want the number in the eeprom to deduct by 1, then perform rest of my code.
when the eeprom reaches 0 i need to code to stop running. (sort of like a trial, when trial reaches 0 stop working)
ive been looking into reading the eeprom and writing to it and updating it from the arduino examples but im a little confused on how i store the number,
do i need to break the number down into bytes before storing it ?
would anyone be able to give me an example of how to store the number 25 into the eeprom ?
Regards
What is the initial value? If the initial value is less than 256, no. If it is greater than 255, you will.
Where?
int someAddr = ???;
byte someValu = 25;
EEPROM.write(someAddr, someValu);
Thanks PaulS,
yes the initial value will be 250, thanks for clearing that up, :slight_smile:
i know this is simple stuff for some, new to but
int eepromMemory = 1;
byte counterValue = 250;
int subtractCounter = 1;
#include <EEPROM.h>
//EEPROM.write(eepromMemory, counterValue);
Serial.println(counterValue);
counterValue = counterValue - subtractCounter;
EEPROM.update(eepromMemory, counterValue);
[code]
so basically what ive written, i believe should set an inital value into the eeprom of 250, then it dose a simple subtraction, then rewrite the value to the eeprom,
however a reboot of my arduino just resets the counter to 250 again.
i though after i did the calculation and used
[code]
this should then set the value to its new value for next time the eeprom is read ?
You need one sketch to set the initial value. Then, you need another sketch to read, decrement, and save, the value.
so i assume once ive run the 1st sketch i then upload the 2nd sketch which reads the eeprom, subtracts x from current number then re-writes the eeprom.
that's fine but how would i go about defining my counter variable ?
would i just use
int counterValue = subtractValue
or
int counterValue =
or even
int counterValue
Thanks
What you are doing in the code you posted looks fine.
basically im trying to set a value in the eeprom. (which ive managed to do in sketch 1)
sketch 2
is ment to read the value from eeprom, then subtract 1 then re-write the eeprom so eventually the eeprom value will read 0.
however when i try to compile my read and subtract sketch i get the following
WRITE EEPROM WITH 250 VALUE SKETCH
int eepromMemory = 1;  // set the location of the memory were going to use in the eeprom/
int counterValue = 250;  //  set the inital value for our countdown
#include <EEPROM.h> // include the eerpom libary
// set the serial monitor
READ / SUBTRACT / WRITE SKETCH
int counterValue; //  set the var
EEPROM.read(eepromMemory, counterValue);
should be
counterValue = EEPROM.read(eepromMemory);
ok so ive set the following code to turn on a LED when the counter hits 0
but when i reset the board at 0 it loops back to 254 ?
this is what the code looks like
int LED = 13;
  pinMode(LED, OUTPUT);
Serial.println("Previous eeprom Value");
Serial.println("New eeprom Value");
if (counterValue > 0) {
   digitalWrite(LED, LOW);
// need to find a way to erase the eeprom to prevent it from looping.
} else {digitalWrite(LED, HIGH);}
Unprogrammed EEPROM locations will have 0xff (255) stored there. Are you seeing an effect of that?
Because you tell it to.
Don't decrement counterValue if it is already 0.
what an idiot i am.....
thanks again paul,
all i can say is ive learn so much with the help you have provided over the few projects ive done.
