I'm trying to upload data information to ThingSpeak, using Arduino Mega 2560 and the ESP8266 for the WiFi connection. For now I'm just trying to upload data using a DHT22 for temperature/humidity but I can't do it and I'm not sure where the error is. I can't get a graphic's data in thingspeak. Help me please!
This is my code:
// Librería para usar SoftwareSerial
#include <SoftwareSerial.h>
#include <DHT.h>
SoftwareSerial espSerial = SoftwareSerial(18,19); // arduino RX pin=2 arduino TX pin=3
// Conecte el pin 2 al pin TX del ESP8266 - Conecte el pin 3 al pin RX del ESP8266
#define DHTPIN 12 // Conecte el pin de datos al pin 5 del Arduino
#define DHTTYPE DHT22 //defina el tipo de sensor
DHT dht(DHTPIN, DHTTYPE); //crear objeto DHT
String apiKey = "RWAB7FVFE5F9PU2Q"; // Remplace con el API KEY WRITE de ThingSpeak
String ssid="GALAXYA12C89F"; // Wifi network SSID
String password ="gianderi12"; // Wifi network password
//======================================================================== tiempoRespuesta
void tiempoRespuesta(int waitTime){
long t=millis();
char c;
while (t+waitTime>millis()){
if (espSerial.available()){
c=espSerial.read();
Serial.print(c);
boolean thingSpeakWrite(float value1, float value2){
String cmd = "AT+CIPSTART="TCP",""; // Conexión TCP
cmd += "184.106.153.149"; // api.thingspeak.com
cmd += "",80";
espSerial.println(cmd); //Mandar datos seriales al ESP8266
if(espSerial.find("Error")){
Serial.println("AT+CIPSTART error");
return false;
String getStr = "GET /update?api_key="; // Prepara el String GET a mandar
getStr += apiKey;
getStr +="&field1=";
getStr += String(value1);//convertir de flotante a String
getStr +="&field2=";
getStr += String(value2);
// getStr +="&field3=";
// getStr += String(value3);
getStr += "\r\n\r\n";
// enviar la longitud de la cadena
cmd = "AT+CIPSEND=";
cmd += String(getStr.length());
delay(100);
if(espSerial.find(">")){//si Ok envíe la cadena de GET
espSerial.print(getStr);
else{
espSerial.println("AT+CIPCLOSE");
// Que el usuario sepa que no se están enviando datos
return false;
return true;
//================================================================================ setup
dht.begin(); // Empiece la comunicacnión con el sensor DHT11
espSerial.begin(115200); // Habilite la comunicación serial
//La velocidad problable del módulo ESP8266 es 115200 bauds
// Por esa razón se debe configurar primero esta velocidad (115200) y correr el programa las líneas de código
// a continuación cambian la velocidad pero necesitan que se les quite el comentario.
// Corra el código con las siguientes líneas descomentadas y luego vuelva a correr pero cambiando 115200 por
//9600 y volviendo a comentar las líneas
espSerial.println("AT+CWMODE=1"); // Configure el ESP8266 como cliente
tiempoRespuesta(1000);
espSerial.println("AT+CWJAP=""+ssid+"",""+password+"""); // Configure el SSID y password para conexión WIFI
tiempoRespuesta(5000);
Serial.println("Setup completed");
// Lea los valores del sensor
float t = dht.readTemperature();
float h = dht.readHumidity();
if (isnan(t) || isnan(h)) {
Serial.println("Fallo al leer el sensor");
else {
Serial.println("Temp="+String(t)+"°C"); //imprimimos los valores en el monitor serial
Serial.println("Humedad="+String(h)+"%");
thingSpeakWrite(t,h); // Escriba los valores a ThingSpeak
// thingspeak necesita al menos 15 segundos para actualizar
delay(16000);
