Hi, I need to use EPSON M-T532 thermal printer with Arduino Uno,
can somebody share with me info about connection?
can I connect directly RxD, TxD, GND (TTL level) or I need to use MAX232 for level correction?
thanks
regards
Well the data sheet says its an RS232 interface...................
I've deleted your other cross post @pasicr.
Cross posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes writing a detailed answer on this thread, without knowing that someone else already did the same in the other thread.
Repeated cross posting will result in a suspension from the forum.
In the future, please take some time to pick the forum section that best suits the topic of your question and then only post once to that forum section. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum section. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Thanks for your info,
about my subject, can somebody help with advice how to print anything from Arduino Uno to Epson T-M532? thanks in advance, regards
