Since you get the gist of what I'm trying to do, would you mind looking at why the comparitor isn't returning an equality result?
Thanks, I appreciate your time. For the record, if I allow it to default to case-sensitive by using .equals, it works fine (in matching-case situations).
Is this a trick question? "on" will never equal "ON!", regardless of case, because the exclamation mark isn't present in the "on" string. Mind you, I don't use String due to it's prevalence in newbie errors, so maybe there's more to it.
Serial.readString() includes any line-ending characters sent by Serial Monitor. You can use Val.trim() to remove any leading and trailing whitespace (space, tab, newline, return). Insert that between Val = Serial.readString(); and if (Val.equalsIgnoreCase(onVal)) {.
Since, and only since, you had to make a comment on "newbie errors", read the code before you condemn an entire community of programmers. The string with the exclamation point is a serial.print output and has nothing to do with the comparison.
It prints the entered string verbatim, but my money's on the guys suggesting to remove the implicit endline character. I'll verify and post the result.
Well, an honest question "Is this a trick question", based on a failed observation(you're quite right about the source of the "ON!") was answered with a too-sensitive riposte indicating you thought I was calling you a newbie, so I guess the pot called the kettle black. No problem here, but you might want to put your sabre away.
C
It would be Serial.readstring().trim(); since 'trim' is a function. I don't know if this is safe because you are modifying a String that doesn't belong to you. Better to copy the returned String into your own String variable before you modify it.
