erorr uploading to board.
#include <dht.h>
dht DHT;
#define DHT11_PIN 13
void setup(){
  pinMode(13, OUTPUT);
 digitalWrite(12, HIGH);
  int chk = DHT.read11(DHT11_PIN);
  Serial.print("Temperature = C ");
  Serial.println(DHT.temperature);
  Serial.print("Humidity = ");
  Serial.println(DHT.humidity);
erorr code:
Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: “Arduino/Genuino Uno”
Sketch uses 4094 bytes (12%) of program storage space. Maximum is 32256 bytes.
Global variables use 241 bytes (11%) of dynamic memory, leaving 1807 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
Invalid library found in C:\Users\eatfi\OneDrive\Documents\Arduino\libraries\lazer_on_g8: C:\Users\eatfi\OneDrive\Documents\Arduino\libraries\lazer_on_g8
avrdude: ser_open(): can’t open device “\.\COM3”: Access is denied.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Exception in thread “Thread-97” java.util.ConcurrentModificationException
at java.util.LinkedList$ListItr.checkForComodification(LinkedList.java:966)
at java.util.LinkedList$ListItr.next(LinkedList.java:888)
at processing.app.BaseNoGui.populateImportToLibraryTable(BaseNoGui.java:822)
at processing.app.BaseNoGui.onBoardOrPortChange(BaseNoGui.java:685)
at processing.app.Base.onBoardOrPortChange(Base.java:1313)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2198)
at java.lang.Thread.run(Thread.java:748)
“Show verbose output during compilation”
option enabled in File → Preferences.
It's all about
can't open device "\.\COM3": Access is denied
Some other driver has control of COM3.
