Err: multiple types in one declaration
Error: multiple types in one declaration
I'm using a UART connection to read GPS data. I have a structure for the position data and other parameters but here is the annoyance. In my first setup I was using a christmas present (Arduino 2560) but now I'm using a Pro Mini (ATmega 328). The code is the same but it throws up this error and points me to the struct or rather the semi-colon of the struct. The struct contains uint8_t and int32_t but both are int so should not cause problems and I have tried having just uint8_t or int32_t and I still get the same error.
I have googled for answers from any programming site and struck out with the answers given so far (semi colon, previous definitions, library definitions etc) but I just cannot shift these errors. The stated line is the longitude value and it is handled the same as the other values so I am unsure why anything weird may come from the handling side but in the interest of full disclosure the handling parts are included too.
Error message
E:\Arduino\arduino-0022\hardware\tools\avr\bin\avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=22 -IE:\Arduino\arduino-0022\hardware\arduino\cores\arduino -IE:\Arduino\arduino-0022\libraries\Wire -IE:\Arduino\Sketchbook\ArduDriver\testbed\libraries\RC
In file included from C:\Users_\AppData\Local\Temp\build2983500146223259179.tmp\ArduDriver.cpp:21:
C:\Users_
\AppData\Local\Temp\build2983500146223259179.tmp/defines.h:30: error: multiple types in one declaration
defines.h
//********Definitions********//
#define SDA 4  // not needed but it reminds you not to use them
#define SCL 5  // not needed but it reminds you not to use them
#define BUF_LEN 60  // Length for GPS buffer
#define ToRad (0.01745329252)	// *pi/180
#define ToDeg (57.2957795131)	// *180/pi
//******Analogue inputs******//
#define SONAR 0
//********PWM outputs********//
// #define blah 3
// #define blip 5
// #define blop 6
#define ESC 9
#define SERVO 10
// #define argh 11
struct Location {
	uint8_t		id;				// id parameter
	uint8_t		options;			// option parameter
	uint8_t		stg;				// stage parameter
	int32_t		alt;				// altitude parameter
	int32_t		lat;				// latitude parameter
	int32_t		lng;				// longitude parameter
struct Location	home 		= {0,0,0,0,0,0};	// home location
struct Location	prev_WP 	= {0,0,0,0,0,0};	// last waypoint
struct Location	cur_loc		= {0,0,0,0,0,0};	// current location
struct Location	next_WP		= {0,0,0,0,0,0};
struct XYZ {
  uint16_t x;
  uint16_t y;
  uint16_t z;
struct XYZ mag			= {0,0,0};
struct XYZ gyro			= {0,0,0};
struct XYZ accel		= {0,0,0};
struct readings {
		uint16_t	raw;
		uint16_t	avg;
struct readings sonar		= {0,0};
GPS Handling
cur_loc.lat 		= join_4_bytes(&MTK_buffer[0])*10;
cur_loc.lng 			= join_4_bytes(&MTK_buffer[4])*10;
cur_loc.alt 			= join_4_bytes(&MTK_buffer[8]);			//alt_MSL M*100
ground_speed 		= join_4_bytes(&MTK_buffer[12]);			//M*100
ground_course	 	= join_4_bytes(&MTK_buffer[16]) / 10000;	// Heading 2D
NumSats			= MTK_buffer[20];
GPS_fix			= MTK_buffer[21];
iTOW 			= join_4_bytes(&MTK_buffer[22]);
join_4_bytes
int32_t join_4_bytes(byte Buffer[])
	longUnion.byte[3] = *Buffer;
	longUnion.byte[2] = *(Buffer+1);
	longUnion.byte[1] = *(Buffer+2);
	longUnion.byte[0] = *(Buffer+3);
	return(longUnion.dword);
What is the smallest sketch that still exhibits this fault?
I suspect a name clash with something defined in another header file that you're including because those names defined at global scope in defines.h are very frequently used words that could easily clash with a #define or something else that you can't see.
Try renaming your structures and global variable instances of those structures one by one to see if it goes away.
AWOL:
I cannot remove parts without more errors being thrown.
Tried three different naming conventions and still got no where so I typed it out again just below and deleted it and BAM. Fixed that one :smiley:
Lesson to everyone:
If you have checked for duplicates, missing semi-colons, clashes, poor defintions, library problems but still have the error. Just retype it underneath and delete. This will check you don't have any strange characters affecting compilation.
