erratic behaviour when introducing lcd print
Hi!
I am using a dht22 to monitor humidity and temperature, and I would like to print the values on a lcd.
here is the code
#include "DHT.h"
#define thresholdmax 27        //Setting the temperature threshold
#define thresholdmin 25        //Setting the temperature threshold
#define DHTPIN 13              // what pin we're connected to
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
//const int relay1 =  8;     // the number of the relay 1 pin
const int relay2 =  9;     // the number of the relay 2 pin
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
  //  pinMode(relay1, OUTPUT);
  pinMode(relay2, OUTPUT);
  lcd.begin(16, 2);
  dht.begin();
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  lcd.setCursor(0, 0);
  lcd.print("Temp: ");
  lcd.print(t);
  lcd.print("C");
  lcd.setCursor(0, 1);
  lcd.print("Humidity: ");
  lcd.print(h);
  lcd.print("%");
  // check if returns are valid, if they are NaN (not a number) then something went wrong!
  if (isnan(t) || isnan(h)) {
    Serial.println("Failed to read from DHT");
  else {
    Serial.print("Humidity: ");
    Serial.print(h);
    Serial.print(" %\t");
    Serial.print("Temperature: ");
    Serial.print(t);
    Serial.println(" *C");
    if (t < thresholdmin) {
      //      digitalWrite(relay1, HIGH);
      digitalWrite(relay2, HIGH);
    else if (t > thresholdmax) {
      //      digitalWrite(relay1, LOW);
      digitalWrite(relay2, LOW);
This code generates an erratic behaviour in which the relay is being constantly turned off and on. As soon as I remove the following part, the behaviour is normal.
  lcd.print(t);
  lcd.print("C");
  lcd.print(h);
  lcd.print("%");
Evidently it is not in the right part of the loop, or I am missing something else. Anybody sees my mistake?
thanks!
LiquidCrystal lcd(8, 9, 4, 5, 6, 7); Remind us which pins the relays are connected to.
obviously...
thanks AWOL!
