Hello,
I am trying to run a motor off cell battery using power saving technique on Attiny85. I started with this simple program to see if the motor runs ok after processor wake up. I do not use battery for tests, I use regular 3.3V power supply. Much to my surprise the motor does not run for 1 sec every time as it is supposed to. Sometimes it runs for 1 sec, but most of the times it runs for much shorter periods. I would also say, that these periods are not the same.
I hooked up motor through ULN2003 Darlington pair chip, running Attiny85 at 8MHz (burned fuses before tests).
I am using Nathan Seidle's example code from here.
#include <avr/sleep.h> //Needed for sleep_mode
#include <avr/wdt.h> //Needed to enable/disable watch dog timer
const byte motor = 0;
ISR(WDT_vect) {
pinMode(motor, OUTPUT);
//Power down various bits of hardware to lower power usage
set_sleep_mode(SLEEP_MODE_PWR_DOWN); //Power down everything, wake up from WDT
sleep_enable();
ADCSRA &= ~(1<<ADEN); //Disable ADC, saves ~230uA
setup_watchdog(6); //Setup watchdog to go off after 1sec
sleep_mode(); //Go to sleep! Wake up 1sec later and check light
ADCSRA |= (1<<ADEN); //Enable ADC
wdt_disable(); //Turn off the WDT!!
delay(2000);
digitalWrite(motor, HIGH);
digitalWrite(motor, LOW);
//Sets the watchdog timer to wake us up, but not reset
//0=16ms, 1=32ms, 2=64ms, 3=128ms, 4=250ms, 5=500ms
//6=1sec, 7=2sec, 8=4sec, 9=8sec
//From: http://interface.khm.de/index.php/lab/experiments/sleep_watchdog_battery/
void setup_watchdog(int timerPrescaler) {
if (timerPrescaler > 9 ) timerPrescaler = 9; //Limit incoming amount to legal settings
byte bb = timerPrescaler & 7;
if (timerPrescaler > 7) bb |= (1<<5); //Set the special 5th bit if necessary
//This order of commands is important and cannot be combined
MCUSR &= ~(1<<WDRF); //Clear the watch dog reset
WDTCR |= (1<<WDCE) | (1<<WDE); //Set WD_change enable, set WD enable
WDTCR = bb; //Set new watchdog timeout value
WDTCR |= _BV(WDIE); //Set the interrupt enable, this will keep unit from resetting after each int
