Bonsoir, j'ai un petit soucis au niveau de la compilation de mon programme j’obtiens:
Arduino : 1.6.11 (Windows 10), Carte : "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\benoit_msi\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10611 -build-path C:\Users\BENOIT~1\AppData\Local\Temp\build96456217b31246cb7e89a1ac7d9b460f.tmp -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose F:\projet arduino universite\code_final_corriger\code_final_corriger.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\benoit_msi\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10611 -build-path C:\Users\BENOIT~1\AppData\Local\Temp\build96456217b31246cb7e89a1ac7d9b460f.tmp -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose F:\projet arduino universite\code_final_corriger\code_final_corriger.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\BENOIT~1\AppData\Local\Temp\build96456217b31246cb7e89a1ac7d9b460f.tmp\sketch\code_final_corriger.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src" "C:\Users\BENOIT~1\AppData\Local\Temp\build96456217b31246cb7e89a1ac7d9b460f.tmp\sketch\code_final_corriger.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src" "C:\Program Files (x86)\Arduino\libraries\RobotIRremote\src\IRremote.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src" "C:\Program Files (x86)\Arduino\libraries\RobotIRremote\src\IRremoteTools.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src" "C:\Users\BENOIT~1\AppData\Local\Temp\build96456217b31246cb7e89a1ac7d9b460f.tmp\sketch\code_final_corriger.ino.cpp" -o "C:\Users\BENOIT~1\AppData\Local\Temp\build96456217b31246cb7e89a1ac7d9b460f.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\BENOIT~1\AppData\Local\Temp\build96456217b31246cb7e89a1ac7d9b460f.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
Compilation du croquis...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src" "C:\Users\BENOIT~1\AppData\Local\Temp\build96456217b31246cb7e89a1ac7d9b460f.tmp\sketch\code_final_corriger.ino.cpp" -o "C:\Users\BENOIT~1\AppData\Local\Temp\build96456217b31246cb7e89a1ac7d9b460f.tmp\sketch\code_final_corriger.ino.cpp.o"
Compiling libraries...
Compiling library "RobotIRremote"
Utilisation du fichier déjà compilé : C:\Users\BENOIT~1\AppData\Local\Temp\build96456217b31246cb7e89a1ac7d9b460f.tmp\libraries\RobotIRremote\IRremote.cpp.o
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Program Files (x86)\Arduino\libraries\RobotIRremote\src" "C:\Program Files (x86)\Arduino\libraries\RobotIRremote\src\IRremoteTools.cpp" -o "C:\Users\BENOIT~1\AppData\Local\Temp\build96456217b31246cb7e89a1ac7d9b460f.tmp\libraries\RobotIRremote\IRremoteTools.cpp.o"
C:\Program Files (x86)\Arduino\libraries\RobotIRremote\src\IRremoteTools.cpp:5:16: error: 'TKD2' was not declared in this scopeint RECV_PIN = TKD2; // the pin the IR receiver is connected to
Utilisation de la bibliothèque RobotIRremote version 1.0.2 dans le dossier: C:\Program Files (x86)\Arduino\libraries\RobotIRremote
exit status 1
Erreur de compilation pour la carte Arduino/Genuino Uno
merci de votre aide
