Erreur de code pour un stabilisateur de gopro et j'aurais besoin d'aide
// 3 servo planar stabilization system
// CN
// Mar 2018
// Based on Jeff Rowber's work found at
// https://github.com/jrowberg/i2cdevlib/blob/master/Arduino/MPU6050/MPU6050.cpp
// Use at your own risk.
// This code is placed under the MIT License (MIT)
// Copyright (c) 2016 woojay poynter
//Permission is hereby granted, free of charge, to any person obtaining a copy
//of this software and associated documentation files (the "Software"), to deal
//in the Software without restriction, including without limitation the rights
//to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
//copies of the Software, and to permit persons to whom the Software is
//furnished to do so, subject to the following conditions:
//The above copyright notice and this permission notice shall be included in all
//copies or substantial portions of the Software.
//THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
//IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
//FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
//AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
//LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
//OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
//SOFTWARE.
#include <Servo.h>
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
//#include "MPU6050.h" // not necessary if using MotionApps include file
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
#include "Wire.h"
#endif
#define LED_PIN 13
bool blinkState = true;
Servo Servo1;   // First Servo off the chassis
Servo Servo2;   // Second Servo off the chassis
Servo Servo3;   // Third Servo
int button = 7; //pushbutton
int ButState = LOW;
float YawOffset = 0;
int val;
int Servo1Pos = 0;
int Servo2Pos = 0;
int Servo3Pos = 0;
float mpuPitch = 0;
float mpuRoll = 0;
float mpuYaw = 0;
float mpuYawStart = 0;
// define MPU instance
MPU6050 mpu;                    // class default I2C address is 0x68; specific I2C addresses may be passed as a parameter here
// MPU control/status vars
uint8_t mpuIntStatus;   // holds actual interrupt status byte from MPU
uint8_t devStatus;      // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize;    // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount;     // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
// orientation/motion vars
Quaternion q;           // [w, x, y, z]         quaternion container
VectorInt16 aa;         // [x, y, z]            accel sensor measurements
VectorInt16 aaReal;     // [x, y, z]            gravity-free accel sensor measurements
VectorInt16 aaWorld;    // [x, y, z]            world-frame accel sensor measurements
VectorFloat gravity;    // [x, y, z]            gravity vector
float ypr[3];           // [yaw, pitch, roll]   yaw/pitch/roll container and gravity vector
// relative ypr[x] usage based on sensor orientation when mounted, e.g. ypr[PITCH]
#define PITCH   1     // defines the position within ypr[x] variable for PITCH; may vary due to sensor orientation when mounted
#define ROLL  2     // defines the position within ypr[x] variable for ROLL; may vary due to sensor orientation when mounted
#define YAW   0     // defines the position within ypr[x] variable for YAW; may vary due to sensor orientation when mounted
// ===                      INITIAL SETUP                       ===
    //digitalRead (button, ButState);
  Servo1.attach(10);  // attaches the servo on D11 to the servo object
  Servo2.attach(11);  // Second servo on D11
  Servo3.attach(9); // Yaw servo on D9
  delay(50);
  Servo1.write(60);	// These are command checks to see if the servos work and
  Servo2.write(60);	// to help w/ the initial installation.
  Servo3.write(60);
  delay(500);		// Make sure these movements are clear from the rest of the chassis.
  Servo1.write(130);
  Servo2.write(120);
  Servo3.write(120);
  Servo1.write(0);
  Servo2.write(90);
  Servo3.write(90);
  // join I2C bus (I2Cdev library doesn't do this automatically)
  Wire.begin();
  TWBR = 24; // 400kHz I2C clock (200kHz if CPU is 8MHz)
#elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
  Fastwire::setup(400, true);
#endif
  while (!Serial);      // wait for Leonardo enumeration, others continue immediately
  // initialize device
  mpu.initialize();
  // load and configure the DMP
  devStatus = mpu.dmpInitialize();
  // INPUT CALIBRATED OFFSETS HERE; SPECIFIC FOR EACH UNIT AND EACH MOUNTING CONFIGURATION!!!!
  mpu.setXGyroOffset(-603);
  mpu.setYGyroOffset(103);
  mpu.setZGyroOffset(65);
  mpu.setXAccelOffset(-2456);
  mpu.setYAccelOffset(-3596);
  mpu.setZAccelOffset(1026);
  // make sure it worked (returns 0 if so)
  if (devStatus == 0)
    // turn on the DMP, now that it's ready
  //  Serial.println(F("Enabling DMP"));
    mpu.setDMPEnabled(true);
    // enable Arduino interrupt detection
 //   Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)"));
    mpuIntStatus = mpu.getIntStatus();
    // get expected DMP packet size for later comparison
    packetSize = mpu.dmpGetFIFOPacketSize();
  else return
  // configure LED for output
  pinMode(LED_PIN, OUTPUT);
  pinMode (button, INPUT);
  mpu.dmpGetQuaternion(&q, fifoBuffer);
  mpu.dmpGetGravity(&gravity, &q);
  mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
  mpuYawStart  = ypr[YAW] * 180 / M_PI; //get Yaw starting point.  Used for offsetting.
} // setup()
// ===                    MAIN PROGRAM LOOP                     ===
void loop(void)
  processAccelGyro();
    Servo1.write(mpuPitch + 73); // These values used to level Pitch and Roll.  Change as necessary.
    Servo2.write(mpuRoll + 80);
    if (val == LOW) Servo3.write(mpuYaw + YawOffset); // This allows yaw while adding offset.
    val = digitalRead (button);
    // my trouble shooting screen prints
    Serial.print ("Pitch = "); Serial.print (mpuPitch); Serial.print ("\t");
    Serial.print ("Roll = "); Serial.print (mpuRoll); Serial.print ("\t");
    Serial.print ("Yaw = "); Serial.print (mpuYaw); Serial.print ("\t");
    Serial.print ("YawSt = "); Serial.print (mpuYawStart); Serial.print ("\t");
    Serial.print ("Offset = "); Serial.print (YawOffset); Serial.print ("\t");
    Serial.print ("Buttonstate = "); Serial.print (val); Serial.print ("\t");
    Serial.println (" ");
    if (val == HIGH) YawOffset = (-mpuYaw + 63); // Pushbutton to reset Yaw axis. Change value to align.
}   // loop()
// ===                    PROCESS ACCEL/GYRO IF AVAILABLE       ===
void processAccelGyro()
  // Get INT_STATUS byte
  // get current FIFO count
  fifoCount = mpu.getFIFOCount();
  // check for overflow (this should never happen unless our code is too inefficient)
  if ((mpuIntStatus & 0x10) || fifoCount == 1024)
    // reset so we can continue cleanly
    mpu.resetFIFO();
//    Serial.println(F("FIFO overflow!"));
    return;
  if (mpuIntStatus & 0x02)  // otherwise continue processing
    // check for correct available data length
    if (fifoCount < packetSize)
      return; //  fifoCount = mpu.getFIFOCount();
    // read a packet from FIFO
    mpu.getFIFOBytes(fifoBuffer, packetSize);
    // track FIFO count here in case there is > 1 packet available
    fifoCount -= packetSize;
    // flush buffer to prevent overflow
    mpu.resetFIFO();
    // display Euler angles in degrees
    mpuPitch = ypr[PITCH] * 180 / M_PI;
    mpuRoll = ypr[ROLL] * 180 / M_PI;
    mpuYaw  = ypr[YAW] * 180 / M_PI;
    mpu.resetFIFO();
    // blink LED to indicate activity
    blinkState = !blinkState;
    digitalWrite(LED_PIN, blinkState);
    mpu.resetFIFO();
Edit pour être conforme aux recommandations : mise en forme code
je suppose que ceci n'a pas a été lu :
Et l'erreur est .......
On doit probablement essayer de deviner :
  • erreur à la compilation ?
  • erreur à l'exécution ?
Un nouveau jeu :upside_down_face:
themysterio est un pseudo qui se mérite.
