Erreur de compilation
bonjour ,
j 'essai de compiler un programme sur mon esp8226 lolin D1 mini pro
et j 'ai cette erreur "Compilation error: exit status 1"
In file included from /Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/ESP8266WiFi.h:39,
                 from /Users/christophegallier/Documents/Arduino/sketch_nov03c/sketch_nov03c.ino:1:
/Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/WiFiClient.h:89:10: error: conflicting return type specified for 'virtual size_t WiFiClient::availableForWrite()'
   89 |   size_t availableForWrite();
In file included from /Users/christophegallier/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.2/cores/esp8266/Stream.h:27,
                 from /Users/christophegallier/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.2/cores/esp8266/HardwareSerial.h:32,
                 from /Users/christophegallier/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.2/cores/esp8266/Arduino.h:303,
                 from /Users/christophegallier/Library/Caches/arduino/sketches/9615E5F266910362447EF83E718C2169/sketch/sketch_nov03c.ino.cpp:1:
/Users/christophegallier/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.2/cores/esp8266/Print.h:80:21: note: overridden function is 'virtual int Print::availableForWrite()'
   80 |         virtual int availableForWrite() { return 0; }
In file included from /Users/christophegallier/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.2/libraries/ESP8266mDNS/src/LEAmDNS.h:119,
                 from /Users/christophegallier/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.2/libraries/ESP8266mDNS/src/ESP8266mDNS.h:48,
                 from /Users/christophegallier/Documents/Arduino/sketch_nov03c/sketch_nov03c.ino:2:
/Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/include/UdpContext.h:265:5: error: 'CONST' does not name a type
  265 |     CONST IPAddress& getRemoteAddress() CONST
/Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/include/UdpContext.h:422:15: error: 'CONST' has not been declared
  422 |     bool send(CONST ip_addr_t* addr = 0, uint16_t port = 0)
/Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/include/UdpContext.h:422:30: error: expected ',' or '...' before '*' token
/Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/include/UdpContext.h:607:13: error: 'CONST' has not been declared
  607 |             CONST ip_addr_t *srcaddr, u16_t srcport)
/Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/include/UdpContext.h:607:29: error: expected ',' or '...' before '*' token
/Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/include/UdpContext.h: In member function 'bool UdpContext::listen(const IPAddress&, uint16_t)':
/Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/include/UdpContext.h:128:24: error: invalid conversion from 'void (*)(void*, udp_pcb*, pbuf*, int)' to 'udp_recv_fn' {aka 'void (*)(void*, udp_pcb*, pbuf*, const ip4_addr*, short unsigned int)'} [-fpermissive]
  128 |         udp_recv(_pcb, &_s_recv, (void *) this);
In file included from /Users/christophegallier/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.2/libraries/ESP8266mDNS/src/LEAmDNS.h:117,
/Users/christophegallier/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.2/tools/sdk/lwip2/include/lwip/udp.h:128:67: note:   initializing argument 2 of 'void udp_recv(udp_pcb*, udp_recv_fn, void*)'
  128 | void             udp_recv       (struct udp_pcb *pcb, udp_recv_fn recv,
/Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/include/UdpContext.h: In member function 'bool UdpContext::send(int)':
/Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/include/UdpContext.h:448:14: error: 'addr' was not declared in this scope; did you mean 'ip_addr'?
  448 |         if (!addr) {
      |              ip_addr
/Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/include/UdpContext.h:450:13: error: 'port' was not declared in this scope
  450 |             port = _pcb->remote_port;
/Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/include/UdpContext.h:458:47: error: 'addr' was not declared in this scope; did you mean 'ip_addr'?
  458 |         err_t err = udp_sendto(_pcb, tx_copy, addr, port);
      |                                               ip_addr
/Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/include/UdpContext.h:458:53: error: 'port' was not declared in this scope
/Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/include/UdpContext.h: In static member function 'static void UdpContext::_s_recv(void*, udp_pcb*, pbuf*, int)':
/Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/include/UdpContext.h:609:60: error: 'srcaddr' was not declared in this scope
  609 |         reinterpret_cast<UdpContext*>(arg)->_recv(upcb, p, srcaddr, srcport);
/Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi/src/include/UdpContext.h:609:69: error: 'srcport' was not declared in this scope; did you mean 'short'?
      |        short
In file included from /Users/christophegallier/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.2/libraries/ESP8266WebServer/src/ESP8266WebServer.h:349,
                 from /Users/christophegallier/Documents/Arduino/sketch_nov03c/sketch_nov03c.ino:5:
/Users/christophegallier/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.2/libraries/ESP8266WebServer/src/ESP8266WebServer-impl.h: In instantiation of 'void esp8266webserver::ESP8266WebServerTemplate<ServerType>::handleClient() [with ServerType = WiFiServer]':
/Users/christophegallier/Documents/Arduino/sketch_nov03c/sketch_nov03c.ino:646:23:   required from here
/Users/christophegallier/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.2/libraries/ESP8266WebServer/src/ESP8266WebServer-impl.h:284:33: error: 'class WiFiServer' has no member named 'accept'; did you mean '_accept'?
  284 |     ClientType client = _server.accept();
      |                         _accept
/Users/christophegallier/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.2/libraries/ESP8266WebServer/src/ESP8266WebServer-impl.h:372:22: error: 'class WiFiServer' has no member named 'hasClientData'; did you mean 'hasClient'?
  372 |         if ((_server.hasClientData() || _server.hasMaxPendingClients())
      |              hasClient
/Users/christophegallier/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.2/libraries/ESP8266WebServer/src/ESP8266WebServer-impl.h:372:49: error: 'class WiFiServer' has no member named 'hasMaxPendingClients'
Plusieurs bibliothèque trouvées pour "ESP8266WiFi.h"
  Utilisé: /Users/christophegallier/Documents/Arduino/libraries/ESP8266WiFi
  Non utilisé: /Users/christophegallier/Library/Arduino15/packages/esp8266/hardware/esp8266/3.1.2/libraries/ESP8266WiFi
Plusieurs bibliothèque trouvées pour "TimeLib.h"
  Utilisé: /Users/christophegallier/Documents/Arduino/libraries/Time
  Non utilisé: /Users/christophegallier/Documents/Arduino/libraries/Time-master
Plusieurs bibliothèque trouvées pour "PubSubClient.h"
  Utilisé: /Users/christophegallier/Documents/Arduino/libraries/PubSubClient
  Non utilisé: /Users/christophegallier/Documents/Arduino/libraries/Antares_ESP8266_MQTT
exit status 1
je vous joint le projet
merci a vous
Bonjour
ne posez pas vos questions dans la catégorie "projets finis".. Posez les dans le forum francophone principal ➜ je déplace votre sujet pour vous pour cette fois.
Ces erreurs viennent des bibliothèques que tu utilises et qui sont dans le kernel de l'esp8266. Ça semble être un problème d'installation de ce kernel. As-tu déjà fait des projets sur esp8266 qui fonctionnaient ?
