Je suis en Windows XP pro, avec le logiciel 1.6.1 et l'Arduino UNO R3.
J'ai construit le shield décrit ICI et j'ai téléchargé le sketch SUIVANT:
HVFuse - Use High Voltage Programming Mode to Set Fuses on ATmega328
09/23/08 Jeff Keyzer http://mightyohm.com
The HV programming routines are based on those described in the
ATmega48/88/168 datasheet 2545M-AVR-09/07, pg. 290-297
This program should work for other members of the AVR family, but has only
been verified to work with the ATmega168. If it works for you, please
let me know! http://mightyohm.com/blog/contact/
// Desired fuse configuration
#define HFUSE 0xD9 // Default for ATmega328, for others see // ELECTROPEPPER CHANGED THIS LINES
#define LFUSE 0x62 // http://www.engbedded.com/cgi-bin/fc.cgi //
// Pin Assignments
#define DATA PORTD // PORTD = Arduino Digital pins 0-7
#define DATAD DDRD // Data direction register for DATA port
#define VCC 8
#define RDY 12 // RDY/!BSY signal from target
#define OE 11
#define WR 10
#define BS1 9
#define XA0 13
#define XA1 18 // Analog inputs 0-5 can be addressed as
#define PAGEL 19 // digital outputs 14-19
#define RST 14 // Output to level shifter for !RESET
#define BS2 16
#define XTAL1 17
#define BUTTON 15 // Run button
void setup() // run once, when the sketch starts
// Set up control lines for HV parallel programming
DATA = 0x00; // Clear digital pins 0-7
DATAD = 0xFF; // set digital pins 0-7 as outputs
pinMode(VCC, OUTPUT);
pinMode(RDY, INPUT);
pinMode(OE, OUTPUT);
pinMode(WR, OUTPUT);
pinMode(BS1, OUTPUT);
pinMode(XA0, OUTPUT);
pinMode(XA1, OUTPUT);
pinMode(PAGEL, OUTPUT);
pinMode(RST, OUTPUT); // signal to level shifter for +12V !RESET
pinMode(BS2, OUTPUT);
pinMode(XTAL1, OUTPUT);
pinMode(BUTTON, INPUT);
digitalWrite(BUTTON, HIGH); // turn on pullup resistor
// Initialize output pins as needed
digitalWrite(RST, HIGH); // Level shifter is inverting, this shuts off 12V
void loop() // run over and over again
while(digitalRead(BUTTON) == HIGH) { // wait until button is pressed
// Initialize pins to enter programming mode
digitalWrite(PAGEL, LOW);
digitalWrite(XA1, LOW);
digitalWrite(XA0, LOW);
digitalWrite(BS1, LOW);
digitalWrite(BS2, LOW);
// Enter programming mode
digitalWrite(VCC, HIGH); // Apply VCC to start programming process
digitalWrite(WR, HIGH); // Now we can assert !OE and !WR
digitalWrite(OE, HIGH);
delay(1);
digitalWrite(RST, LOW); // Apply 12V to !RESET thru level shifter
delay(1);
// Now we're in programming mode until RST is set HIGH again
// First we program HFUSE
sendcmd(B01000000); // Send command to enable fuse programming mode
writefuse(HFUSE, true);
// Now we program LFUSE
sendcmd(B01000000);
writefuse(LFUSE, false);
delay(1000); // wait a while to allow button to be released
// Exit programming mode
// Turn off all outputs
DATA = 0x00;
digitalWrite(OE, LOW);
digitalWrite(WR, LOW);
digitalWrite(VCC, LOW);
void sendcmd(byte command) // Send command to target AVR
// Set controls for command mode
digitalWrite(XA1, HIGH);
//DATA = B01000000; // Command to load fuse bits
DATA = command;
digitalWrite(XTAL1, HIGH); // pulse XTAL to send command to target
delay(1);
digitalWrite(XTAL1, LOW);
//delay(1);
void writefuse(byte fuse, boolean highbyte) // write high or low fuse to AVR
// if highbyte = true, then we program HFUSE, otherwise LFUSE
// Enable data loading
digitalWrite(XA0, HIGH);
delay(1);
// Write fuse
DATA = fuse; // set desired fuse value
delay(1);
if(highbyte == true)
digitalWrite(BS1, HIGH); // program HFUSE
delay(1);
delay(100);
Une erreur se produit à la compilation. Malheureusement, je ne suis pas assez féru d'Arduino pour comprendre et localiser. Quelqu'un pourrait-il m'aider à voir clair ?
Voici l'erreur:
Arduino : 1.6.1 (Windows XP), Carte : "Arduino Uno"
C:\Program Files\Arduino/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10601 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files\Arduino\hardware\arduino\avr\variants\standard C:\DOCUME~1\JMCo\LOCALS~1\Temp\build1081808405617244358.tmp\sketch_sep01a.cpp -o C:\DOCUME~1\JMCo\LOCALS~1\Temp\build1081808405617244358.tmp\sketch_sep01a.cpp.o
hvfuse.ino: In function 'void setup()':
hvfuse.ino:32:6: error: redefinition of 'void setup()'
sketch_sep01a.ino:1:6: error: 'void setup()' previously defined here
hvfuse.ino: In function 'void loop()':
hvfuse.ino:56:6: error: redefinition of 'void loop()'
sketch_sep01a.ino:6:6: error: 'void loop()' previously defined here
Erreur lors de la compilation.
