Bonjour à tous, j'espère que vous allez bien.
J'utilise un simple code Arduino, mais je ne sais pas comment résoudre cette erreur, alors j'utilise le module wifi ESP01, Realtime Database comme base de donnée et VOICI MON PROGRAMME :
#include <ESP8266WiFi.h>
#include <FirebaseESP8266.h>
#define FIREBASE_HOST "******" // L'URL de votre projet Firebase sans "http:", "\" et "/"
#define FIREBASE_AUTH "******" // Votre secret de base de données Firebase
#define WIFI_SSID "******* " // votre SSID WiFi auquel votre NodeMCU se connecte
#define WIFI_PASSWORD "*****" // Mot de passe de votre réseau wifi
FirebaseData firebaseData;
String val1;
Serial.begin(115200); // Select the same baud rate if you want to see the datas on Serial Monitor
Serial.println("Serial communication started\n");
WiFi.begin(WIFI_SSID, WIFI_PASSWORD); //try to connect with wifi
Serial.print("Connecting to ");
Serial.print(WIFI_SSID);
Serial.print(".");
Serial.print("Connected to ");
Serial.println(WIFI_SSID);
Serial.print("IP Address is : ");
Serial.println(WiFi.localIP()); //print local IP address
Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH); // connect to firebase
Firebase.reconnectWiFi(true);
if (Firebase.getString(firebaseData, "/lampe1"))
val1 = firebaseData.stringData();
Serial.println(val1);
VOICI l'ERREUR :
WARNING: Spurious .github folder in 'Firebase ESP8266 Client' library
In file included from C:\Users\ULTRAPC\Documents\Arduino\libraries\Firebase-ESP8266-master\src/common.h:45:0,
from C:\Users\ULTRAPC\Documents\Arduino\libraries\Firebase-ESP8266-master\src/Utils.h:37,
from C:\Users\ULTRAPC\Documents\Arduino\libraries\Firebase-ESP8266-master\src/signer/Signer.h:37,
from C:\Users\ULTRAPC\Documents\Arduino\libraries\Firebase-ESP8266-master\src/FirebaseESP8266.h:51,
from C:\Users\ULTRAPC\Desktop\ESP\ESP.ino:2:
C:\Users\ULTRAPC\Documents\Arduino\libraries\Firebase-ESP8266-master\src/wcs/esp8266/FB_HTTPClient.h:50:30: fatal error: CertStoreBearSSL.h: No such file or directory
#include <CertStoreBearSSL.h>
compilation terminated.
exit status 1
Error compiling for board Generic ESP8266 Module.
THANK YOU
