Bonjour,
Je suis actuellement face à un problème. J'ai un code conséquent avec lequel je souhaite créer une librairie mais l'IDE considère que je définie plusieurs fois mes fonction.
libraries/Lum_feu/Lum_feu.cpp.o (symbol from plugin): In function Lum_feu::Lum_feu(int, float, float, float, float, int, int, int, int, int, int, int, int)': (.text+0x0): multiple definition of Lum_feu::Lum_feu(int, float, float, float, float, int, int, int, int, int, int, int, int)'
sketch/Lum_feu.cpp.o (symbol from plugin):(.text+0x0): first defined here
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld: Disabling relaxation: it will not work with multiple definitions
libraries/Lum_feu/Lum_feu.cpp.o (symbol from plugin): In function Lum_feu::Lum_feu(int, float, float, float, float, int, int, int, int, int, int, int, int)': (.text+0x0): multiple definition of Lum_feu::BeginLum()'
libraries/Lum_feu/Lum_feu.cpp.o (symbol from plugin): In function Lum_feu::Lum_feu(int, float, float, float, float, int, int, int, int, int, int, int, int)': (.text+0x0): multiple definition of Lum_feu::initialNeo()'
libraries/Lum_feu/Lum_feu.cpp.o (symbol from plugin): In function Lum_feu::Lum_feu(int, float, float, float, float, int, int, int, int, int, int, int, int)': (.text+0x0): multiple definition of Lum_feu::DivA(int, int, int)'
libraries/Lum_feu/Lum_feu.cpp.o (symbol from plugin): In function Lum_feu::Lum_feu(int, float, float, float, float, int, int, int, int, int, int, int, int)': (.text+0x0): multiple definition of Lum_feu::DivB(int, int, int)'
libraries/Lum_feu/Lum_feu.cpp.o (symbol from plugin): In function Lum_feu::Lum_feu(int, float, float, float, float, int, int, int, int, int, int, int, int)': (.text+0x0): multiple definition of Lum_feu::DivC(int, int, int)'
libraries/Lum_feu/Lum_feu.cpp.o (symbol from plugin): In function Lum_feu::Lum_feu(int, float, float, float, float, int, int, int, int, int, int, int, int)': (.text+0x0): multiple definition of Lum_feu::DivD(int, int, int)'
libraries/Lum_feu/Lum_feu.cpp.o (symbol from plugin): In function Lum_feu::Lum_feu(int, float, float, float, float, int, int, int, int, int, int, int, int)': (.text+0x0): multiple definition of Lum_feu::Main()'
libraries/Lum_feu/Lum_feu.cpp.o (symbol from plugin): In function Lum_feu::Lum_feu(int, float, float, float, float, int, int, int, int, int, int, int, int)': (.text+0x0): multiple definition of Lum_feu::NumDiv(int)'
collect2: error: ld returned 1 exit status
exit status 1
Erreur de compilation pour la carte Arduino/Genuino Mega or Mega 2560
Quelqu'un aurait une idée? Je n'arrive pas à trouver pourquoi.
PS= ci-joint le code .zip avec fichier .ino .cpp et .h
Bib_Lum_feu_V6.zip (4.1 KB)
