Erreur librairie <wire.h>
Bonjour à tous,
Je souhaite compiler un programme fournit par libelium afin de mettre en oeuvre un module RF Lora.
J’utilise pour cela une carte Arduino M0 pro et l’IDE 1.7.8.
Lorsque je compile mon programme, j’ai cette erreur de compilation :
In file included from C:\Users\Richard\Documents\Arduino\libraries\arduinoLoRa\arduinoLoRa.cpp:30:0:
C:\Users\Richard\Documents\Arduino\libraries\arduinoLoRa\../arduino-api/arduinoMultiprotocol.h:20:20: fatal error: Wire.h: No such file or directory
   #include <Wire.h>
compilation terminated.
Error compiling.
Comment puis je résoudre ce problème car je ne vois pas pourquoi il ne trouve pas ma librairie ?
Je vous donne le code source :
 *  LoRa 868 / 915MHz SX1272 LoRa module
 *  Copyright (C) Libelium Comunicaciones Distribuidas S.L.
 *  http://www.libelium.com
 *  This program is free software: you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License as published by
 *  the Free Software Foundation, either version 3 of the License, or
 *  (at your option) any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *  GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License
 *  along with this program.  If not, see http://www.gnu.org/licenses/.
 *  Version:           1.1
 *  Design:            David Gascón
 *  Implementation:    Covadonga Albiñana & Victor Boria
// Include the SX1272 and SPI library:
//#include "SX1272.h"
#include <SPI.h>
#include <arduinoLoRa.h>
int e;
  // Print a start message
  Serial.println(F("SX1272 module configuration in Arduino"));
  // Power ON the module
  e = sx1272.ON();
  Serial.print(F("Setting power ON: state "));
  Serial.println(e, DEC);
  // Set transmission mode and print the result
  e = sx1272.setMode(4);
  Serial.print(F("Setting Mode: state "));
  // Set header
  e = sx1272.setHeaderON();
  Serial.print(F("Setting Header ON: state "));
  // Select frequency channel
  e = sx1272.setChannel(CH_10_868);
  Serial.print(F("Setting Channel: state "));
  // Set CRC
  e = sx1272.setCRC_ON();
  Serial.print(F("Setting CRC ON: state "));
  // Select output power (Max, High or Low)
  e = sx1272.setPower('H');
  Serial.print(F("Setting Power: state "));
  // Set the node address and print the result
  e = sx1272.setNodeAddress(3);
  Serial.print(F("Setting node address: state "));
  // Print a success message
  Serial.println(F("SX1272 successfully configured"));
void loop(void)
Cordialement,
