erreur Taille binaire du croquis : 1 084 octets (d'un max de 32 256 octets)
Bonjour,
Je viens de tester mon arduino avec le code exemple basic blink (la led marche bien et je peux changer la fréquence) mais
je voudrais savoir si cette erreur est habituelle ou pas .
Voici le code .excusez-moi pour la page. j'ai mis tous les codes qui apparaissent en rouge chez moi (sauf le dernier que j'ai tronqué.
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void store_char(unsigned char, ring_buffer*)':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:98: warning: comparison between signed and unsigned integer expressions
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In function 'void __vector_18()':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:127: warning: unused variable 'c'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'void HardwareSerial::begin(long unsigned int, byte)':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:368: warning: unused variable 'current_config'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp: In member function 'virtual size_t HardwareSerial::write(uint8_t)':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\HardwareSerial.cpp:467: warning: comparison between signed and unsigned integer expressions
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\Print.cpp: In member function 'size_t Print::print(const __FlashStringHelper*)':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\Print.cpp:44: warning: '__progmem__' attribute ignored
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino\Tone.cpp:119: warning: only initialized variables can be placed into program memory area
avrdude: Version 5.11, compiled on Sep  2 2011 at 19:38:36
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware/tools/avr/etc/avrdude.conf"
         Using Port                    : \\.\COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
avrdude: Send: A [41] . [80]   [20]
[s]... PARTIE TRONQUE
..PARTIE TRONQUE[/s]
avrdude: Send: t [74] . [00] < [3c] F [46]   [20]
avrdude: Recv: . [f8] . [94] f [66] # [23] ! [21] . [f4] . [8c] . [91] . [90] . [95] . [89] # [23] . [02] . [c0] . [8c] . [91] . [89] + [2b] . [8c] . [93] / [2f] . [bf] . [08] . [95] . [cf] . [93] . [df] . [93] . [0e] . [94] > [3e] . [01] . [0e] . [94] . [97] . [00] . [c0] . [e0] . [d0] . [e0] . [0e] . [94] . [80] . [00]   [20] . [97] . [e1] . [f3] . [0e] . [94] . [00] . [00] . [f9] . [cf] . [f8] . [94] . [ff] . [cf] . [0d] . [00]
### | 100% 0.20s
avrdude: verifying ...
avrdude: 1084 bytes of flash verified
avrdude: Send: Q [51]   [20]
avrdude done.  Thank you.
C'est quoi qui te perturbe ?
Le compilateur ne t'indique pas d'erreur (sinon tu n'aurais pas pu charger le code) mais des alarmes "Warning".
Un Warning n’empêche pas de compiler mais signale
  • des "choses" à éviter :
  • ou des choses inutiles parce que écrite mais non utilisées :
Quant à la partie transfert vers le micro le mieux est de lire la notice d'avrdude (nom du logiciel qui assure le transfert vers le micro-controleur).
De toute façon si tu trouve:
C'est que tout c'est bien passé.
Ok merci. Avec cette carte que j'ai achetée sur internet en chine, j'avais peur qu'il y est des composants défectueux (surtout quelle doit géré un relai qui lui-même gère du 220V). Je te remercie de ton aide.
nono007:
Jette un œil attentif du coté des opto-coupleurs pour faire l'interface entre la carte micro-controleur et le relais 220V
