Erreur :variable or field 'calcCRC' declared void
je veut faire passer un tableau en argument d'une fonction mais j'obtient cette erreur lors de la compilation
comm_modbus.cpp:
#include <Crc16.h>
Crc16 crc;
#include "Arduino_MachineControl.h"
using namespace machinecontrol;
#include "comm_modbus.h"
byte SlaveID = 0x01;
byte FunctionID;
byte addressHI;
byte addressLO;
byte quantityHI = 0x00;
byte quantityLO = 0x02;
byte totalByteWrite = 0x04;
byte Value24;
byte Value16;
byte Value8;
byte Value0;
byte crcHI;
byte crcLO;
int trameRecus[9];
int trameTraiter [9];
byte check[2];
void initModbus(){
    // Wait for Serial or start after 2.5s
    for (auto const timeout = millis() + 2500; !Serial && timeout < millis(); delay(500))
    delay(2500);
    Serial.println("Start RS485 initialization");
    // Set the PMC Communication Protocols to default config
    comm_protocols.init();
    // RS485/RS232 default config is:
    // - RS485 mode
    // - Half Duplex
    // - No A/B and Y/Z 120 Ohm termination enabled
    // Enable the RS485/RS232 system
    comm_protocols.rs485Enable(true);
    // Specify baudrate, and preamble and postamble times for RS485 communication
    comm_protocols.rs485.begin(19200,SERIAL_8E1 ,0, 500);
    // Start in receive mode
    comm_protocols.rs485.receive();
    Serial.println("Initialization done!");
long ModbusRead(unsigned int addrMB){
      FunctionID = 0x03;
      addrModbus(addrMB);
      byte trame [] = {SlaveID,FunctionID,addressHI,addressLO,quantityHI,quantityLO};
      calcCRC();
      byte trameReadComplet []={SlaveID,FunctionID,addressHI,addressLO,quantityHI,quantityLO,crcHI,crcLO};
        // Disable receive mode before transmission
        comm_protocols.rs485.noReceive();
        comm_protocols.rs485.beginTransmission();
        comm_protocols.rs485.write(trameReadComplet[0]);
        comm_protocols.rs485.write(trameReadComplet[1]);
        comm_protocols.rs485.write(trameReadComplet[2]);
        comm_protocols.rs485.write(trameReadComplet[3]);
        comm_protocols.rs485.write(trameReadComplet[4]);
        comm_protocols.rs485.write(trameReadComplet[5]);
        comm_protocols.rs485.write(trameReadComplet[6]);
        comm_protocols.rs485.write(trameReadComplet[7]);
        comm_protocols.rs485.endTransmission();
        // Re-enable receive mode after transmission
    auto const timeout = millis() + 500;
    while (comm_protocols.rs485.available() < 9){
        if (millis()> timeout){
          Serial.println("communication timeout!");
          Serial.println("erreur : ");
          while(comm_protocols.rs485.available()){
            Serial.println(comm_protocols.rs485.read());
    if (comm_protocols.rs485.available()==9){
      long value;
      reception();
      value = VARvalue();
      return value;
void ModbusWrite(unsigned int addrMB, long ValueMB){
  FunctionID = 0x10;
  addrModbus(addrMB);
  ValueModbus(ValueMB);
  byte trame [] = {SlaveID,FunctionID,addressHI,addressLO,quantityHI,quantityLO,totalByteWrite,Value24,Value16,Value8,Value0};
  calcCRC(trame);
   byte trameComplet []={SlaveID,FunctionID,addressHI,addressLO,quantityHI,quantityLO,totalByteWrite,Value24,Value16,Value8,Value0,crcHI,crcLO};
        comm_protocols.rs485.write(trameWriteComplet[0]);
        comm_protocols.rs485.write(trameWriteComplet[1]);
        comm_protocols.rs485.write(trameWriteComplet[2]);
        comm_protocols.rs485.write(trameWriteComplet[3]);
        comm_protocols.rs485.write(trameWriteComplet[4]);
        comm_protocols.rs485.write(trameWriteComplet[5]);
        comm_protocols.rs485.write(trameWriteComplet[6]);
        comm_protocols.rs485.write(trameWriteComplet[7]);
        comm_protocols.rs485.write(trameWriteComplet[8]);
        comm_protocols.rs485.write(trameWriteComplet[9]);
        comm_protocols.rs485.write(trameWriteComplet[10]);
void addrModbus(unsigned int addresseMB){
  addressHI = (addresseMB >> 8) & 0xFF; //highbyte
  addressLO = (addresseMB & 0xFF);      //lowbyte
void ValueModbus(long valMB){
    Value24 = (valMB & 0xFF000000) >> 24;
    Value16 = (valMB & 0x00FF0000) >> 16;
    Value8  = (valMB & 0x0000FF00) >> 8;
    Value0  = valMB & 0xFF;
void calcCRC(byte trame []){
   unsigned short crcTrame;
   int sizeTrame= sizeof(trame);
    crc.clearCrc();
    for(int i=0;i< sizeTrame;i++)
      Serial.print("byte ");
      Serial.print(i);
      Serial.print(" = ");
      Serial.println(trame[i],HEX);
     crc.updateCrc(trame[i]);
    crcTrame = crc.Modbus(trame,0,sizeTrame);
    check[1] = (crcTrame >> 8) & 0xFF; //highbyte
    check[0] = (crcTrame & 0xFF);      //lowbyte
    crcHI = check[0],HEX;
    crcLO = check[1],HEX;
    Serial.print("Modbus crcHI = 0x");
    Serial.println(crcHI,HEX);
    Serial.print("Modbus crcLO = 0x");
    Serial.println(crcLO,HEX);
long VARvalue()
  long Value = 0;
  int expo = 0;
  int multi = 0;
  for( int i = 3 ;i <= trameRecus[2]+2;i++){
    expo = 6-i;
    multi = pow(256,expo);
    trameRecus[i]= trameRecus[i] * multi;
    Value = Value + trameRecus[i];
  Serial.print("valeur reel = ");
  Serial.println(Value);
  return Value;
void reception(){
  int compteur = 0;
  byte ValueModbus;
  while (comm_protocols.rs485.available()> 0){
      ValueModbus = comm_protocols.rs485.read();
      Serial.println("Reception :");
      Serial.println(ValueModbus);
      trameRecus[compteur] = ValueModbus;
      compteur++;
comm_modbus.h:
void initModbus();
long ModbusRead(unsigned int);
void ModbusWrite(unsigned int, long);
void addrModbus(unsigned int);
void ValueModbus(long);
void calcCRC(array byte);
long VARvalue();
void reception();
l'erreur se fait sur la ligne
Array byte n’est pas un type
Essayez avec byte*
Attention on perd la taille du tableau lors d’un passage de paramètres , ceci ne fonctionne pas.
   int sizeTrame= sizeof(trame); // vous allez obtenir la taille d’un pointeur, pas du tableau
donc à moins que le tableau soit de taille connue, on passe aussi souvent le nombre d’éléments à prendre en compte
void calcCRC( byte* tableau, size_t nbElements) {…}
Ou
void calcCRC( byte tableau[], size_t nbElements) {…}
Et vous faites-le sizeof lors de l’appel si le tableau est connu à ce niveau là
et dans mon fichier comm_modbus.h je dois lui mettre quoi en type de ma fonction ?
pour le moment je lui ai mit :
void calcCRC(byte[],int);
La même chose mais sans le code
Vous pouvez éventuellement omettre les noms de variables
Une fonction qui s'appelle calcCRC, on en attend qu'elle calcule un CRC.
Et donc qu'elle renvoie la valeur qu'elle a calculé.
Donc le prototype devrait être:
unsigned long calcCRC ( const byte* tableau, size_t nb_elements );
L'attribut const permet de l'employer sur un tableau déclaré constant.
elle me le renvoie bien mas pas en retour de fonction, le CRC calculer elle met directement la valeur dans une variable qui ici est
byte crcHI
byte crcLO
Du coup ta fonction n'est pas directement réutilisable dans un autre projet, à moins d'avoir aussi une variable globale du même nom.
Ou, si tu devais un jour calculer 2 CRC sur deux tableaux, il faudrait la retoucher.
Pour de la bonne programmation, solide, réutilisable, une fonction doit renvoyer son résultat par return.
Pourquoi passer par des variables global au lieu du retour de la fonction qui serait plus logique ?
+1, tout à fait d'accord.
ou en passant les paramètres par pointeur ou référence en C++ (pratique quand on en a plusieurs), la fonction retournant alors un message d'erreur (si ça c'est mal passé).
(sinon on peut retourner une structure)
