erreur
bonjour,
j'ai cette erreur :
Ce croquis est destiné à être utilisé avec le bouclier TFT LCD. Assurez-vous que USE_ADAFRUIT_SHIELD_PINOUT est #défini dans l’Adafruit_TFTLCD. h fichier de la bibliothèque.
j'utilise ceci
// Paint example specifically for the TFTLCD Arduino shield.
// If using the breakout board, use the tftpaint.pde sketch instead!
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_TFTLCD.h> // Hardware-specific library
#include <TouchScreen.h>
#if defined(__SAM3X8E__)
    #undef __FlashStringHelper::F(string_literal)
    #define F(string_literal) string_literal
#endif
#ifndef USE_ADAFRUIT_SHIELD_PINOUT
 #error "This sketch is intended for use with the TFT LCD Shield. Make sure that USE_ADAFRUIT_SHIELD_PINOUT is #defined in the Adafruit_TFTLCD.h library file."
#endif
// These are the pins for the shield!
#define YP A1  // must be an analog pin, use "An" notation!
#define XM A2  // must be an analog pin, use "An" notation!
#define YM 7   // can be a digital pin
#define XP 6   // can be a digital pin
#ifdef __SAM3X8E__
  #define TS_MINX 125
  #define TS_MINY 170
  #define TS_MAXX 880
  #define TS_MAXY 940
#else
  #define TS_MINX  150
  #define TS_MINY  120
  #define TS_MAXX  920
  #define TS_MAXY  940
#endif
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
#define LCD_CS A3
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
// Assign human-readable names to some common 16-bit color values:
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
Adafruit_TFTLCD tft;
#define BOXSIZE   40
#define PENRADIUS  4
int oldcolor, currentcolor;
void setup(void) {
  Serial.println(F("Paint!"));
  tft.reset();
  uint16_t identifier = tft.readID();
  if(identifier == 0x9325) {
    Serial.println(F("Found ILI9325 LCD driver"));
  } else if(identifier == 0x9328) {
    Serial.println(F("Found ILI9328 LCD driver"));
  } else if(identifier == 0x7575) {
    Serial.println(F("Found HX8347G LCD driver"));
    Serial.print(F("Unknown LCD driver chip: "));
    Serial.println(identifier, HEX);
    return;
  tft.begin(identifier);
  tft.fillScreen(BLACK);
  tft.fillRect(0, 0, BOXSIZE, BOXSIZE, RED);
  tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, YELLOW);
  tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, GREEN);
  tft.fillRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, CYAN);
  tft.fillRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, BLUE);
  tft.fillRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, MAGENTA);
  // tft.fillRect(BOXSIZE*6, 0, BOXSIZE, BOXSIZE, WHITE);
  tft.drawRect(0, 0, BOXSIZE, BOXSIZE, WHITE);
  currentcolor = RED;
  pinMode(13, OUTPUT);
#define MINPRESSURE 10
#define MAXPRESSURE 1000
  digitalWrite(13, HIGH);
  TSPoint p = ts.getPoint();
  digitalWrite(13, LOW);
  // if sharing pins, you'll need to fix the directions of the touchscreen pins
  //pinMode(XP, OUTPUT);
  pinMode(XM, OUTPUT);
  pinMode(YP, OUTPUT);
  //pinMode(YM, OUTPUT);
  // we have some minimum pressure we consider 'valid'
  // pressure of 0 means no pressing!
  if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
    Serial.print("X = "); Serial.print(p.x);
    Serial.print("\tY = "); Serial.print(p.y);
    Serial.print("\tPressure = "); Serial.println(p.z);
    if (p.y < (TS_MINY-5)) {
      Serial.println("erase");
      // press the bottom of the screen to erase
      tft.fillRect(0, BOXSIZE, tft.width(), tft.height()-BOXSIZE, BLACK);
    // scale from 0->1023 to tft.width
    p.x = map(p.x, TS_MINX, TS_MAXX, tft.width(), 0);
    p.y = map(p.y, TS_MINY, TS_MAXY, tft.height(), 0);
    Serial.print("("); Serial.print(p.x);
    Serial.print(", "); Serial.print(p.y);
    Serial.println(")");
    if (p.y < BOXSIZE) {
       oldcolor = currentcolor;
       if (p.x < BOXSIZE) {
         currentcolor = RED;
       } else if (p.x < BOXSIZE*2) {
         currentcolor = YELLOW;
         tft.drawRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, WHITE);
       } else if (p.x < BOXSIZE*3) {
         currentcolor = GREEN;
         tft.drawRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, WHITE);
       } else if (p.x < BOXSIZE*4) {
         currentcolor = CYAN;
         tft.drawRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, WHITE);
       } else if (p.x < BOXSIZE*5) {
         currentcolor = BLUE;
         tft.drawRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, WHITE);
       } else if (p.x < BOXSIZE*6) {
         currentcolor = MAGENTA;
         tft.drawRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, WHITE);
       if (oldcolor != currentcolor) {
          if (oldcolor == RED) tft.fillRect(0, 0, BOXSIZE, BOXSIZE, RED);
          if (oldcolor == YELLOW) tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, YELLOW);
          if (oldcolor == GREEN) tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, GREEN);
          if (oldcolor == CYAN) tft.fillRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, CYAN);
          if (oldcolor == BLUE) tft.fillRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, BLUE);
          if (oldcolor == MAGENTA) tft.fillRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, MAGENTA);
    if (((p.y-PENRADIUS) > BOXSIZE) && ((p.y+PENRADIUS) < tft.height())) {
      tft.fillCircle(p.x, p.y, PENRADIUS, currentcolor);
donc, j'ai simplement l'écran directement sur le méga
Tu dois avoir dans ton répertoire libraries sous le répertoire arduino, un répertoire dont le nom contient TFTLCD. Dans ce répertoire il y a un fichier appelé ADAFRUIT_TFTLCD.h
Dans ce fichier, il y a la ligne
//#define USE_ADAFRUIT_SHIELD_PINOUT 1
Je pense qu'il faut ôter les deux / au début de cette ligne.
Enregistre le fichier et relance la compilation.
j'ai donc fait ça :
// IMPORTANT: SEE COMMENTS @ LINE 15 REGARDING SHIELD VS BREAKOUT BOARD USAGE.
// Graphics library by ladyada/adafruit with init code from Rossum
// MIT license
#ifndef _ADAFRUIT_TFTLCD_H_
#define _ADAFRUIT_TFTLCD_H_
#if ARDUINO >= 100
 #include "Arduino.h"
#else
 #include "WProgram.h"
#endif
// **** IF USING THE LCD BREAKOUT BOARD, COMMENT OUT THIS NEXT LINE. ****
// **** IF USING THE LCD SHIELD, LEAVE THE LINE ENABLED:             ****
#define USE_ADAFRUIT_SHIELD_PINOUT 1 //[J AI ENLEVÉ LES DEUX / DEVANT CETTE LIGNE
class Adafruit_TFTLCD : public Adafruit_GFX {
 public:
  Adafruit_TFTLCD(uint8_t cs, uint8_t cd, uint8_t wr, uint8_t rd, uint8_t rst);
  Adafruit_TFTLCD(void);
  void     begin(uint16_t id = 0x9325);
  void     drawPixel(int16_t x, int16_t y, uint16_t color);
  void     drawFastHLine(int16_t x0, int16_t y0, int16_t w, uint16_t color);
  void     drawFastVLine(int16_t x0, int16_t y0, int16_t h, uint16_t color);
  void     fillRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t c);
  void     fillScreen(uint16_t color);
  void     reset(void);
  void     setRegisters8(uint8_t *ptr, uint8_t n);
  void     setRegisters16(uint16_t *ptr, uint8_t n);
  void     setRotation(uint8_t x);
       // These methods are public in order for BMP examples to work:
  void     setAddrWindow(int x1, int y1, int x2, int y2);
  void     pushColors(uint16_t *data, uint8_t len, boolean first);
  uint16_t color565(uint8_t r, uint8_t g, uint8_t b),
           readPixel(int16_t x, int16_t y),
           readID(void);
  uint32_t readReg(uint8_t r);
 private:
  void     init(),
           // These items may have previously been defined as macros
           // in pin_magic.h.  If not, function versions are declared:
#ifndef write8
           write8(uint8_t value),
#endif
#ifndef setWriteDir
           setWriteDir(void),
#endif
#ifndef setReadDir
           setReadDir(void),
#endif
#ifndef writeRegister8
           writeRegister8(uint8_t a, uint8_t d),
#endif
#ifndef writeRegister16
           writeRegister16(uint16_t a, uint16_t d),
#endif
    writeRegister24(uint8_t a, uint32_t d),
    writeRegister32(uint8_t a, uint32_t d),
#ifndef writeRegisterPair
           writeRegisterPair(uint8_t aH, uint8_t aL, uint16_t d),
#endif
           setLR(void),
           flood(uint16_t color, uint32_t len);
  uint8_t  driver;
#ifndef read8
  uint8_t  read8fn(void);
  #define  read8isFunctionalized
#endif
  #ifdef __AVR__
    volatile uint8_t *csPort    , *cdPort    , *wrPort    , *rdPort;
 uint8_t           csPinSet  ,  cdPinSet  ,  wrPinSet  ,  rdPinSet  ,
  csPinUnset,  cdPinUnset,  wrPinUnset,  rdPinUnset,
  _reset;
  #endif
    Pio *csPort    , *cdPort    , *wrPort    , *rdPort;
 uint32_t          csPinSet  ,  cdPinSet  ,  wrPinSet  ,  rdPinSet  ,
  _reset;
  #endif
#endif
// For compatibility with sketches written for older versions of library.
// Color function name was changed to 'color565' for parity with 2.2" LCD
// library.
#define Color565 color565
#endif
MAIS J'AI TOUOURS CETTE ERREUR :
Arduino : 1.8.8 (Linux), Carte : "Arduino Mega ADK"
tftpaint_shield:18:3: error: #error "This sketch is intended for use with the TFT LCD Shield. Make sure that USE_ADAFRUIT_SHIELD_PINOUT is #defined in the Adafruit_TFTLCD.h library file."
exit status 1
Ce rapport pourrait être plus détaillé avec
l'option "Afficher les résultats détaillés de la compilation"
activée dans Fichier -> Préférences.
Bonjour
peut être sans rapport, la carte cible est-elle réellement une Mega ADK ?
Code: [Select]
Vous devriez activer l'option "Afficher les résultats détaillés de la compilation"
Comme ça, on pourrait savoir quel est le fichier qui contient le message d'erreur;
je ne peux trouver que :
TFTLCD-Library/examples/tftpaint_shield/tftpaint_shield.ino
Les autres programmes d'exemple n'ont pas les bouts de directives au preprocesseur pour déclencher cette erreur
Je vous proposerais bien de tester avec graphics test, et, si ça marche, de transformer error en warning dans le programme de demo incriminé (mais ça ne reglera pas le problème à la prochaine mise à jour )
al1fch:
Bonjour
Bonjour Al1
8)
Bonne remarque
si le board utilisé est celui de la photo avec l'ecran
ce n'est pas une mega ADK
pomme-poire a certainement selectionner pr erreur megaADK au lieu de mega2560
donc oui, c'est corrigé ! merci. (bonne idé de faire des photos)
ceci dit, ça fonctionne , le téléversement aussi mais écran blanc
il est écrit " tftlcd for arduino uno" mais j'utilise une méga ça pose souci ?
compilteleversement.txt (14.4 KB)
Cette carte semble être prévue pour se connecter sur une UNO ou équivalent. Pour une 2560 dans la librairie Adafruit ils indiquent un pinout différent. Il faudrait voir dans la librairie si cela n'a pas un quelconque effet de bord.
... et en sélectionnant Mega ADK au lieu de Mega 2560 on peur avoir second effet de bord en 'bonus'
al1fch:
non j'ai bien sélectionné mega 3560. C'est corrigé .
effet de bord ??? was ist das ?
La librairie pourrait s'attendre à ce que l'afficheur soit connecté sur les IO qui sont données dans l'entête de la librairie. Je n'ai pas le temps de regarder toute la librairie. J'ai juste noté que dans l'entête il y a un commentaire dans lequel sont spécifiés les connexions suivant le type de carte. Je ne sais pas si c'est suggéré ou imposé.
j'ai trouvé la solution ! enfin, non, j'ai trouvé quelqu’un qui a trouvé la solution
c'est incroyable que ce ne soit pas fourni avec l'écran. (un lien sur le site marchand par exemple)
merci de m'avoir donné un nord pour ma boussole de débutant arduino
Merci beaucoup à vous tous
