bonjour,
si quelqu'un parvient a compiler ce croquis sans erreurs, pas besoin du hardware,
avec les librairies ici
dans les commentaires en anglais çà à l'air de fonctionner pour tout le monde, sauf pour moi....
erreurs compilation obtenues sous IDE 1.8.4 qui n'est pas installé sur C:\ mais sur la partition E:\ du disque dur
Linking everything together...
"E:\arduino-1.8.4\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\elex\AppData\Local\Temp\arduino_build_756680/Parlabtoothscroll.ino.elf" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\sketch\Parlabtoothscroll.ino.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_PZone.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_Parola.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_Parola_Blinds.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_Parola_Close.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_Parola_Diag.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_Parola_Dissolve.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_Parola_Fade.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_Parola_Grow.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_Parola_HScroll.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_Parola_Mesh.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_Parola_Open.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_Parola_Print.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_Parola_Random.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_Parola_Scan.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_Parola_Slice.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_Parola_VScroll.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_Parola-master\MD_Parola_Wipe.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_MAX72XX\MD_MAX72xx.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_MAX72XX\MD_MAX72xx_buf.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_MAX72XX\MD_MAX72xx_font.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\MD_MAX72XX\MD_MAX72xx_pix.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680\libraries\SPI\SPI.cpp.o" "C:\Users\elex\AppData\Local\Temp\arduino_build_756680/core\core.a" "-LC:\Users\elex\AppData\Local\Temp\arduino_build_756680" -lm
C:\Users\elex\AppData\Local\Temp\cchjc2vz.ltrans1.ltrans.o: In function `main':
E:\arduino-1.8.4\hardware\arduino\avr\cores\arduino/main.cpp:43: undefined reference to `setup'
E:\arduino-1.8.4\hardware\arduino\avr\cores\arduino/main.cpp:46: undefined reference to `loop'
collect2.exe: error: ld returned 1 exit status
Utilisation de la bibliothèque MD_Parola-master version 2.6.5 dans le dossier: E:\arduino-1.8.4\libraries\MD_Parola-master
Utilisation de la bibliothèque MD_MAX72XX version 2.9.0 dans le dossier: E:\arduino-1.8.4\libraries\MD_MAX72XX
Utilisation de la bibliothèque SPI version 1.0 dans le dossier: E:\arduino-1.8.4\hardware\arduino\avr\libraries\SPI
exit status 1
Erreur de compilation pour la carte Arduino/Genuino Uno
je précise que les exemples des biblios utilisées compilent sans erreurs
Merci
