Erro compilando... LGT8F328 + BlueRobotics MS5837 library
Ao compilar um programa incluindo a biblioteca BlueRobotics MS5837 para a placa LGT8F328 recebo esta mensagem de erro. Parece haver alguma incompatibilidade mas não sei onde mexer e em qual biblioteca. O erro ocorre em qualquer programa que inclua referida biblioteca somente quando usando a placa LGT8F328.
segue a mensagem :
Arduino: 1.8.19 (Windows 10), Placa:"LGT8F328, 64 (normal), Internal 32MHz, 1, 328P-LQFP32 (e.g. MiniEVB nano-style or WAVGAT), 57600"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\acj\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\acj\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\acj\Documents\Arduino\libraries -fqbn=lgt8fx:avr:328:arduino_isp=disable,clock_source=internal,clock_div=1,variant=modelP,upload_speed=57600 -vid-pid=04D9_B534 -ide-version=10819 -build-path C:\Users\acj\AppData\Local\Temp\arduino_build_191559 -warnings=none -build-cache C:\Users\acj\AppData\Local\Temp\arduino_cache_691015 -prefs=build.warn_data_percentage=75 -verbose C:\Users\acj\Documents\Arduino\libraries\BlueRobotics_MS5837_Library\examples\MS5837_Example\MS5837_Example.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\acj\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\acj\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\acj\Documents\Arduino\libraries -fqbn=lgt8fx:avr:328:arduino_isp=disable,clock_source=internal,clock_div=1,variant=modelP,upload_speed=57600 -vid-pid=04D9_B534 -ide-version=10819 -build-path C:\Users\acj\AppData\Local\Temp\arduino_build_191559 -warnings=none -build-cache C:\Users\acj\AppData\Local\Temp\arduino_cache_691015 -prefs=build.warn_data_percentage=75 -verbose C:\Users\acj\Documents\Arduino\libraries\BlueRobotics_MS5837_Library\examples\MS5837_Example\MS5837_Example.ino
Using board '328' from platform in folder: C:\Users\acj\AppData\Local\Arduino15\packages\lgt8fx\hardware\avr\2.0.7
Using core 'lgt8f' from platform in folder: C:\Users\acj\AppData\Local\Arduino15\packages\lgt8fx\hardware\avr\2.0.7
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DSERIAL_RX_BUFFER_SIZE=64 -DCLOCK_SOURCE=1 -DF_CPU=(32000000L/1) -DF_OSC=32000000L -DF_DIV=1 -DARDUINO=10819 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_AVR "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\cores\\lgt8f" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\variants\\lgt8fx8p" "C:\\Users\\acj\\AppData\\Local\\Temp\\arduino_build_191559\\sketch\\MS5837_Example.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DSERIAL_RX_BUFFER_SIZE=64 -DCLOCK_SOURCE=1 -DF_CPU=(32000000L/1) -DF_OSC=32000000L -DF_DIV=1 -DARDUINO=10819 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_AVR "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\cores\\lgt8f" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\variants\\lgt8fx8p" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\libraries\\Wire" "C:\\Users\\acj\\AppData\\Local\\Temp\\arduino_build_191559\\sketch\\MS5837_Example.ino.cpp" -o nul
Alternatives for MS5837.h: [BlueRobotics_MS5837_Library@1.1.1]
ResolveLibrary(MS5837.h)
  -> candidates: [BlueRobotics_MS5837_Library@1.1.1]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DSERIAL_RX_BUFFER_SIZE=64 -DCLOCK_SOURCE=1 -DF_CPU=(32000000L/1) -DF_OSC=32000000L -DF_DIV=1 -DARDUINO=10819 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_AVR "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\cores\\lgt8f" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\variants\\lgt8fx8p" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\libraries\\Wire" "-IC:\\Users\\acj\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "C:\\Users\\acj\\AppData\\Local\\Temp\\arduino_build_191559\\sketch\\MS5837_Example.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DSERIAL_RX_BUFFER_SIZE=64 -DCLOCK_SOURCE=1 -DF_CPU=(32000000L/1) -DF_OSC=32000000L -DF_DIV=1 -DARDUINO=10819 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_AVR "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\cores\\lgt8f" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\variants\\lgt8fx8p" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\libraries\\Wire" "-IC:\\Users\\acj\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\libraries\\Wire\\utility" "C:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\libraries\\Wire\\Wire.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DSERIAL_RX_BUFFER_SIZE=64 -DCLOCK_SOURCE=1 -DF_CPU=(32000000L/1) -DF_OSC=32000000L -DF_DIV=1 -DARDUINO=10819 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_AVR "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\cores\\lgt8f" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\variants\\lgt8fx8p" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\libraries\\Wire" "-IC:\\Users\\acj\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\libraries\\Wire\\utility" "C:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\libraries\\Wire\\utility\\twi.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DSERIAL_RX_BUFFER_SIZE=64 -DCLOCK_SOURCE=1 -DF_CPU=(32000000L/1) -DF_OSC=32000000L -DF_DIV=1 -DARDUINO=10819 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_AVR "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\cores\\lgt8f" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\variants\\lgt8fx8p" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\libraries\\Wire" "-IC:\\Users\\acj\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "C:\\Users\\acj\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library\\MS5837.cpp" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DSERIAL_RX_BUFFER_SIZE=64 -DCLOCK_SOURCE=1 -DF_CPU=(32000000L/1) -DF_OSC=32000000L -DF_DIV=1 -DARDUINO=10819 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_AVR "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\cores\\lgt8f" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\variants\\lgt8fx8p" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\libraries\\Wire" "-IC:\\Users\\acj\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "C:\\Users\\acj\\AppData\\Local\\Temp\\arduino_build_191559\\sketch\\MS5837_Example.ino.cpp" -o "C:\\Users\\acj\\AppData\\Local\\Temp\\arduino_build_191559\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\acj\\AppData\\Local\\Temp\\arduino_build_191559\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compilando sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DSERIAL_RX_BUFFER_SIZE=64 -DCLOCK_SOURCE=1 -DF_CPU=(32000000L/1) -DF_OSC=32000000L -DF_DIV=1 -DARDUINO=10819 -DARDUINO_AVR_LARDU_328E -DARDUINO_ARCH_AVR "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\cores\\lgt8f" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\variants\\lgt8fx8p" "-IC:\\Users\\acj\\AppData\\Local\\Arduino15\\packages\\lgt8fx\\hardware\\avr\\2.0.7\\libraries\\Wire" "-IC:\\Users\\acj\\Documents\\Arduino\\libraries\\BlueRobotics_MS5837_Library" "C:\\Users\\acj\\AppData\\Local\\Temp\\arduino_build_191559\\sketch\\MS5837_Example.ino.cpp" -o "C:\\Users\\acj\\AppData\\Local\\Temp\\arduino_build_191559\\sketch\\MS5837_Example.ino.cpp.o"
In file included from C:\Users\acj\AppData\Local\Arduino15\packages\lgt8fx\hardware\avr\2.0.7\variants\lgt8fx8p/pins_arduino.h:36:0,
                 from C:\Users\acj\AppData\Local\Arduino15\packages\lgt8fx\hardware\avr\2.0.7\cores\lgt8f/Arduino.h:626,
                 from C:\Users\acj\AppData\Local\Temp\arduino_build_191559\sketch\MS5837_Example.ino.cpp:1:
c:\users\acj\appdata\local\arduino15\packages\lgt8fx\hardware\avr\2.0.7\variants\standard\pins_arduino.h:111:12: error: expected unqualified-id before numeric constant
 #define D1 1 /* PD1 */
C:\Users\acj\Documents\Arduino\libraries\BlueRobotics_MS5837_Library/MS5837.h:88:11: note: in expansion of macro 'D1'
  uint32_t D1, D2;
Usando a biblioteca Wire na versão 1.0 na pasta: C:\Users\acj\AppData\Local\Arduino15\packages\lgt8fx\hardware\avr\2.0.7\libraries\Wire
Usando a biblioteca BlueRobotics_MS5837_Library na versão 1.1.1 na pasta: C:\Users\acj\Documents\Arduino\libraries\BlueRobotics_MS5837_Library
exit status 1
Erro compilando para a placa LGT8F328
SOLVED . SOLUCIONADO. Bastou alterar os nomes das variaveis D1 D2 para D1x D2x na biblioteca BlueRobotics. . cpp e .h
