Erro na programação
Boa noite,
Eu estou já várias semanas a tentar resolver um problema e não consigo.
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
  0x90, 0xA2, 0xDA, 0x00, 0x9B, 0x36 }; //physical mac address
byte ip[] = {
  172, 16, 0, 10 }; // ip in lan
byte gateway[] = {
  172, 16, 0, 1 }; // internet access via router
byte subnet[] = {
  255, 255, 255, 0 }; //subnet mask
EthernetServer server(80); //server port
String readString;
int pin = 9;
boolean ligado = true;
void setup(){
  pinMode(pin, OUTPUT); //pin selected to control
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, subnet);
  server.begin();
  //the pin for the servo co
  //enable serial data print
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  Serial.println("Automação Residencial - EPB"); // so I can keep track of what is loaded
void SendOKpage(EthernetClient &client)
  // send a standard http response header
  client.println("HTTP/1.1 200 OK"); //send new page
  client.println("Content-Type: text/html");
  client.println();
  client.println("<html>");
  client.println("<head>");
  client.println("<title>Remote Automation</title>");
  client.println("<meta http-equiv='Content-Type' content='text/html; charset=ISO-8859-1'>");
  client.println("</head>");
  client.println("<body>");
  client.println("<div id='wrapper'>Remote Automation V1.1");
  client.print("<div id='rele'></div><div id='estado' style='visibility: hidden;'>");
  client.print(ligado);
  client.println("</div>");
  client.println("<div id='botao'></div>");
  client.println("<script>AlteraEstadoRele()</script>");
  client.println("</body>");
  client.println("</html>");
void SendAuthentificationpage(EthernetClient &client)
  client.println("HTTP/1.1 401 Authorization Required");
  client.println("WWW-Authenticate: Basic realm=\"Secure Area\"");
  client.println("Connnection: close");
  client.println();
  client.println("<!DOCTYPE HTML>");
  client.println("<HTML>  <HEAD>   <TITLE>Error</TITLE>");
  client.println(" </HEAD> <BODY><H1>401 Unauthorized.</H1></BODY> </HTML>");
char linebuf[80];
int charcount=0;
boolean authentificated=false;
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    memset(linebuf,0,sizeof(linebuf));
    charcount=0;
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        linebuf[charcount]=c;
        if (charcount<sizeof(linebuf)-1) charcount++;
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          if (authentificated)
            SendOKpage(client);
            SendAuthentificationpage(client);
        if (c == '\n') {
          // you're starting a new line
          if (strstr(linebuf,"Authorization: Basic")>0 && strstr(linebuf,"ZXBiOmVwYjIwMTU=")>0)
            authentificated=true;
          charcount=0;
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    Serial.println(readString); //print to serial monitor for debuging
    if(readString.indexOf("?ligar") >0)//checks for on
      digitalWrite(pin, HIGH);    // set pin 4 high
      Serial.println("On");
      ligado = false;
    else{
      if(readString.indexOf("?desligar") >0)//checks for off
        digitalWrite(pin, LOW);    // set pin 4 low
        Serial.println("Off");
        ligado = true;
    //clearing string for next read
    readString="";
    // close the connection:
    client.stop();
    Serial.println("client disonnected");
no código eu pretendo inserir senha e depois de efetuar login ligar e desligar 1 led ou seja enviar comando, no entanto com esse código faço login, só que ao dar o comando ele não é executado…
Alguém pode ajudar por favor?
Obrigado
1º readString() é uma função do Arduino: Stream.readString() - Arduino Reference
Usa outro nome para a tua variável para não haver confusões.
2º readString nunca toma nenhum valor no teu código logo nunca vais conseguir comparar nada.
