Erro na Verificação
Galera alguém pode me ajudar, sou muito novato e estou tendo problemas com essa programação pois quando mando verificar na IDE ele me dá o seguinte erro:exit status 1
expected ‘}’ at end of input
Ai a baixo o Sketch todo:
#include <SoftwareSerial.h>
#include <espduino.h>
#include <rest.h>
SoftwareSerial espPort(10, 11);
ESP esp(&espPort, &Serial, 9);
REST rest(&esp);
boolean wifiConnected = false;
const int relay1 = 2;
const int relay2 = 3;
const int relay3 = 4;
const int relay4 = 5;
boolean data1 = false;
boolean data2 = false;
boolean data3 = false;
boolean data4 = false;
int loop_count = 0;
char response[266];
char buff[64];
String strId,strData,strCode;
String strData_Last1,strData_Last2,strData_Last3,strData_Last4;
void(* resetFunc) (void) = 0;
void clearBuffer(void) {
for (int i = 0;i<266;i++ ) {
response*=0;*
    void wifiCb(void* response)
  • uint32_t status;*
  • RESPONSE res(response);*
  • if(res.getArgc() == 1) {*
    res.popArgs((uint8_t*)&status, 4);
  • if(status == STATION_GOT_IP) {*
  • Serial.println(“TERHUBUNG KE WIFI”);*
  • wifiConnected = true;*
  • } else {*
  • wifiConnected = false;*
  • pinMode(relay1, OUTPUT);*
  • pinMode(relay2, OUTPUT);*
  • pinMode(relay3, OUTPUT);*
  • pinMode(relay4, OUTPUT);*
  • digitalWrite(relay1,HIGH);*
  • digitalWrite(relay2,HIGH);*
  • digitalWrite(relay3,HIGH);*
  • digitalWrite(relay4,HIGH);*
  • Serial.begin(9600);*
  • espPort.begin(19200);*
  • esp.enable();*
  • delay(500);*
  • esp.reset();*
  • delay(500);*
  • while(!esp.ready());*
  • Serial.println(“ARDUINO: Setup client”);*
  • if(!rest.begin(“api.thingspeak.com”)) {*
  • Serial.println(“ARDUINO: Gagal Setup client”);*
  • while(1);*
  • Serial.println(“ARDUINO: Menghubungkan dengan Wifi”);*
  • esp.wifiCb.attach(&wifiCb);*
  • esp.wifiConnect(“Andy182 Network”,“waipigratis”);*
  • Serial.println(“ARDUINO: System sudah siap!”);*
    loop_start:
  • esp.process();*
  • if(wifiConnected) { *
  • char str_field1[6] , str_field2[6] , str_field3[6] , str_field4[6];*
  • sprintf(buff, “/channels/58419/fields/1/last”);*
  • Serial.println(buff);*
_ rest.get((const char*)buff);_
  • if(rest.getResponse(response, 266) == HTTP_STATUS_OK){*
  • strId = “”;*
  • strData = “”;*
  • strCode = “”;*
  • getData(); *
  • if (strData == “1” || strData == “1.0” || strData == “1.00” ){*
  • digitalWrite(relay1,LOW);*
  • data1 = true;*
  • if (strData == “0” || strData == “-1” || strData == “0.1” || strData == “0.10”){*
  • data1 = false;*
  • else{*
  • hardReset();*
  • resetFunc();*
  • delay(10000);*
  • sprintf(buff, “/channels/58419/fields/2/last”);*
  • strId = “”; strData = “”; strCode = “”;*
  • getData();*
  • if (strData == “1” || strData == “1.0” || strData == “1.00”){*
  • digitalWrite(relay2,LOW);*
  • data2 = true; *
  • data2 = false; *
  • else{*
  • hardReset();*
  • resetFunc();*
  • clearBuffer();*
  • goto loop_start; *
  • delay(10000);*
  • sprintf(buff, “/channels/58419/fields/3/last”);*
  • getData(); // GET DATA*
  • digitalWrite(relay3,LOW);*
  • data3 = true; *
  • data3 = false; *
  • else{*
  • hardReset();*
  • resetFunc();*
  • clearBuffer();*
  • delay(10000);*
  • sprintf(buff, “/channels/58419/fields/4/last”); // field x last Data*
  • digitalWrite(relay4,LOW);*
  • data4 = true; *
  • data4 = false; *
  • else{*
  • hardReset();*
  • resetFunc();*
  • clearBuffer();*
  • delay(10000); *
  • loop_count++;*
  • Serial.println("LOOP : ");*
  • Serial.println(loop_count);*
  • if(loop_count == 6 ){*
  • loop_count = 0;*
  • if(data1) { *
  • dtostrf(1, 1, 1, str_field1); *
  • }else{*
  • dtostrf(0.1, 2, 1, str_field1); *
  • if(data2) {*
  • dtostrf(1, 1, 1, str_field2);*
  • }else{*
  • dtostrf(0.1, 2, 1, str_field2); *
  • if(data3) {*
  • dtostrf(1, 1, 1, str_field3);*
  • }else{*
  • dtostrf(0.1, 2, 1, str_field3); *
  • if(data4) {*
  • dtostrf(1, 1, 1, str_field4);*
  • }else{*
  • dtostrf(0.1, 2, 1, str_field4); *
  • sprintf(buff, “//update?key=65OKK4T6SKM96AVO&field1=%s&field2=%s&field3=%s&field4=%s”,str_field1,str_field2,str_field3,str_field4);*
  • Serial.println(“ARDUINO: Mengirim data terbaru”);*
  • Serial.println(“ARDUINO: Berhasil GET Data”);*
  • getData();*
  • delay(5000);*
  • else{*
void getData(){
  • int i=0,j=0,k=0;*
  • for (i = 0; i < 10; i++){ *
if((response == ‘\r’) || (response == ‘\n’)) {
* else{ *
_ strId += response*;
}*_
_ if (response == ‘\n’){
* i++;
}*_
* Serial.println("");*
* Serial.print("ID : ");*
* Serial.print(strId);*
* for (j = i; j < (i+20); j++){*
* if((response[j] == ‘\r’) || (response[j] == ‘\n’)) {*
* else{ *
* strData += response[j]; *
* if (response[j] == ‘\n’){*
* j++; *
* break;*
* Serial.print("Data : ");*
* Serial.print(strData);*
* for (k = j; k < (j+10); k++){ *
* if((response[k] == ‘\r’) || (response[k] == ‘\n’)) {*
* else{ *
* strCode += response[k]; *
* if (response[k] == ‘\n’){ *
* break;*
* Serial.print("Code : ");*
* Serial.print(strCode); *
* Serial.println(""); *
* boolean hardReset() {*
* String tmpData;*
Tem a certeza que é esse erro que dá? Eu tentei compilar e dá-me outro (ou outro, melhor dizendo) erros!
PS.: Já agora aproveito para dizer que devia ter lido as regras do fórum antes de postar. Há formas de colocar o código num post, que facilitam a leitura e cópia, por exemplo.
Minhas desculpas com relação a postagem do código, vou dar uma verificada nas regras para repostar corretamente, obrigado, e sim para mim na IDE do Arduino só me dá esse erro!
O erro diz-te exactamente o que te falta... provavelmente também te diz a linha (que não indicaste aqui) que nos levaria ao sítio correcto no código.
No entanto, tenho de dizer que este código está extremamente feio e um erro desses não me espanta.
Olha aqui alguns exemplos:
  else{
          if((response == '\r') || (response == '\n')) {
          else{
             strId += response;
