Recentemente comprei um Arduino mega e ao tentar usar o MobiFlight, descobri que o VID PID dele é de Arduino uno, ou seja, era pra estar 2341/0010(VID PID do Mega) e esta 2341/0001(VID PID do Uno). Alguém sabe se tem como consertar isso?
That is unfortunate, but really I'm not sure it matters. Have you had any problem using your Mega? If not, I would suggest just ignoring it. If it does bother you, you could consider contacting the seller you bought it from for a replacement. Or if you prefer the DIY approach, you could update the firmware on the ATmega16U2 following this tutorial:
I believe the instructions about soldering the resistor on that tutorial are outdated and that step is no longer necessary.
I've deleted/merged your other cross-post(s) @Pedro13082005.
Cross posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
