Erroe compiling for board ESP32 Wrover Module 04/12/2022
Arduino: 1.8.13 (Windows 10), Board: "ESP32 Wrover Module, Huge APP (3MB No OTA/1MB SPIFFS), QIO, 80MHz, 921600, None, Disabled"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\hp\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\hp\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\hp\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32wrover:PartitionScheme=huge_app,FlashMode=qio,FlashFreq=80,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\hp\AppData\Local\Temp\arduino_build_435306 -warnings=none -build-cache C:\Users\hp\AppData\Local\Temp\arduino_cache_62604 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mklittlefs.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -prefs=runtime.tools.esptool_py-4.2.1.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -verbose C:\Users\hp\Documents\Arduino\ESP32CAM\ESP32CAM.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\hp\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\hp\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\hp\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32wrover:PartitionScheme=huge_app,FlashMode=qio,FlashFreq=80,UploadSpeed=921600,DebugLevel=none,EraseFlash=none -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\hp\AppData\Local\Temp\arduino_build_435306 -warnings=none -build-cache C:\Users\hp\AppData\Local\Temp\arduino_cache_62604 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mklittlefs.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.riscv32-esp-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-gcc8_4_0-esp-2021r2-patch3.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\gcc8_4_0-esp-2021r2-patch3 -prefs=runtime.tools.mkspiffs.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -prefs=runtime.tools.esptool_py-4.2.1.path=C:\Users\hp\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.2.1 -verbose C:\Users\hp\Documents\Arduino\ESP32CAM\ESP32CAM.ino
Using board 'esp32wrover' from platform in folder: C:\Users\hp\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5
Using core 'esp32' from platform in folder: C:\Users\hp\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5
cmd /c if exist "C:\Users\hp\Documents\Arduino\ESP32CAM\partitions.csv" COPY /y "C:\Users\hp\Documents\Arduino\ESP32CAM\partitions.csv" "C:\Users\hp\AppData\Local\Temp\arduino_build_435306\partitions.csv"
exec: "cmd": executable file not found in %PATH%
Error compiling for board ESP32 Wrover Module.
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
Please post your sketch, using code tags when you do
Maybe have a look at this related thread.
