Error 6 Appearing on Can Bus Setup
I try to run this code and I get result as Error 6. I am using a MPU-6050 as the IMU. How can I fix it?
#include <SPI.h>
#include <mcp_can.h>
const long acl_period_ms = 5;
const long gys_period_ms = 20;
const int CAN_CS_PIN = 10;
MCP_CAN CAN(CAN_CS_PIN);
unsigned char len = 6;
unsigned long acl_id = 0x3FF;
unsigned long gys_id = 0x400;
unsigned char acl_data[6] = {0, 0, 0, 0, 0, 0};
unsigned char gys_data[6] = {0, 0, 0, 0, 0, 0};
unsigned long acl_time = 0;
unsigned long gys_time = 0;
#include<Wire.h>
const int MPU_addr=0x68; // I2C address of the MPU-6050
double AcX, AcY, AcZ, GyX, GyY, GyZ;
char CANSignalConvert(double data, int range, int shift){
int sig = (data + range) * 0xFFFF / (range*2);
int mask = 0xFF << shift;
return (sig & mask) >> shift;
void setup(){
CAN.init_Filt(0, 0, acl_id);
while (CAN_OK != CAN.begin(CAN_500KBPS)) {
Serial.println("CAN initialization retrying.");}
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
void loop(){
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true); // request a total of 14 registers
AcX=Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY=Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ=Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
GyX=Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY=Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ=Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
Serial.print("AcX = "); Serial.print(AcX/16384);
Serial.print(" | AcY = "); Serial.print(AcY/16384);
Serial.print(" | AcZ = "); Serial.print(AcZ/16384);
Serial.print(" | GyX = "); Serial.print(GyX/131);
Serial.print(" | GyY = "); Serial.print(GyY/131);
Serial.print(" | GyZ = "); Serial.println(GyZ/131);
if ((millis() - acl_time) > acl_period_ms){
//reset last transmit time
acl_time = millis();
//put accelerometer data into can_data 8 byte array
acl_data[0] = CANSignalConvert(AcX/16384, 0.05, 8);
acl_data[1] = CANSignalConvert(AcX/16384, 0.05, 0);
acl_data[2] = CANSignalConvert(AcY/16384, 0.05, 8);
acl_data[3] = CANSignalConvert(AcY/16384, 0.05, 0);
acl_data[4] = CANSignalConvert(AcZ/16384, 0.08, 8);
acl_data[5] = CANSignalConvert(AcZ/16384, 0.08, 0);
//send CAN message onto bus
CAN.sendMsgBuf(acl_id, 0, len, acl_data);
if(CAN.sendMsgBuf(acl_id, 0, len, acl_data)==CAN_OK)
Serial.println("OK.");
Serial.println(CAN.sendMsgBuf(acl_id, 0, len, acl_data));
Serial.println("ERROR.");
if ((millis() - gys_time) > gys_period_ms){
gys_time = millis();
gys_data[0] = CANSignalConvert(GyX/131, 20, 8);
gys_data[1] = CANSignalConvert(GyX/131, 20, 0);
gys_data[2] = CANSignalConvert(GyY/131, 20, 8);
gys_data[3] = CANSignalConvert(GyY/131, 20, 0);
gys_data[4] = CANSignalConvert(GyZ/131, 20, 8);
gys_data[5] = CANSignalConvert(GyZ/131, 20, 0);
// CAN.sendMsgBuf(gys_id, 0, len, gys_data);
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What model Arduino are you using.
Thanks.. Tom.... :slight_smile:
