Error: __c causes a section type conflict with __c
Hello,
Thank you for taking a look!
I am having conflict between two or three codes.
I am combining wifimanager “FSparameter” example from github (wifi manager)
  • aRest cloud Pro example from github (internet dashboard)
  • an email code that works with smtp2go.com
I have used the WiFiManager code with email code with much success. I have also used the WiFiManage code with the aRest dashboard code with much success.
When I try and combine the WiFiManager with both email and aRest, I get this error:
With these notes:
In file included from C:\Users****\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/Arduino.h:243:0,
from sketch\test_test.ino.cpp:1:
C:\Users***\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/pgmspace.h:21:51: error: __c causes a section type conflict with __c
#define PSTR(s) (extension({static const char __c PROGMEM = (s); &__c[0];}))
C:\Users*****\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/WString.h:38:76: note: in definition of macro ‘FPSTR’
#define FPSTR(pstr_pointer) (reinterpret_cast<const __FlashStringHelper *>(pstr_pointer))
C:\Users*****\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/WString.h:39:34: note: in expansion of macro ‘PSTR’
#define F(string_literal) (FPSTR(PSTR(string_literal)))
C:\Users****\Documents\Arduino\test_test\test_test.ino:129:18: note: in expansion of macro ‘F’
Serial.println(F(“disconnected”));
C:\Users******\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/pgmspace.h:21:51: note: ‘__c’ was declared here
C:\Users****\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/WString.h:38:76: note: in definition of macro ‘FPSTR’
C:\Users****\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/WString.h:39:34: note: in expansion of macro ‘PSTR’
C:\Users*****\Documents\Arduino\libraries\aREST/aREST.h:300:15: note: in expansion of macro ‘F’
addToBuffer(F(“HTTP/1.1 200 OK\r\nAccess-Control-Allow-Origin: *\r\nAccess-Control-Allow-Methods: POST, GET, PUT, OPTIONS\r\nContent-Type: application/json\r\nConnection: close\r\n\r\n”));
exit status 1
Error compiling.
#include <FS.h>                   //this needs to be first, or it all crashes and burns...
#include <ESP8266WiFi.h>          //https://github.com/esp8266/Arduino
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>          //https://github.com/tzapu/WiFiManager
#include <ArduinoJson.h>          //https://github.com/bblanchon/ArduinoJson
#include <PubSubClient.h>
#include <aREST.h>
// Clients
WiFiClient espClient;
PubSubClient client(espClient);
// Create aREST instance
aREST rest = aREST(client);
// aREST Pro key (that you can get at dashboard.arest.io)
char * key = "your_arest_key";
//define your default values here, if there are different values in config.json, they are overwritten.
char mqtt_server[40];
char mqtt_port[6] = "8080";
char blynk_token[34] = "YOUR_BLYNK_TOKEN";
char server[] = "mail.smtpcorp.com";
WiFiClient client2;
//flag for saving data
bool shouldSaveConfig = false;
//callback notifying us of the need to save config
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
void callback(char* topic, byte* payload, unsigned int length);
byte eRcv()
  byte respCode;
  byte thisByte;
  int loopCount = 0;
  while (!client2.available()) {
    delay(1);
    loopCount++;
    // if nothing received for 10 seconds, timeout
    if (loopCount > 10000) {
      client2.stop();
      Serial.println(F("\r\nTimeout"));
      return 0;
  respCode = client2.peek();
  while (client2.available())
    thisByte = client2.read();
    Serial.write(thisByte);
  if (respCode >= '4')
    //  efail();
    return 0;
  return 1;
  byte sendEmail()
  byte thisByte = 0;
  byte respCode;
  if (client2.connect(server, 2525) == 1) {
    Serial.println(F("connected"));
    Serial.println(F("connection failed"));
    return 0;
  if (!eRcv()) return 0;
  Serial.println(F("Sending EHLO"));
  client2.println("EHLO www.example.com");
  Serial.println(F("Sending auth login"));
  client2.println("auth login");
  Serial.println(F("Sending User"));
  // Change to your base64, ASCII encoded user
  client2.println("base64CODE"); //<---------User
  Serial.println(F("Sending Password"));
  // change to your base64, ASCII encoded password
  client2.println("base64CODE");//<---------Passw
  Serial.println(F("Sending From"));
  // change to your email address (sender)
  client2.println(F("MAIL From:example@example.com"));
  // change to recipient address
  Serial.println(F("Sending To"));
  client2.println(String("RCPT To:example@example.com "));
  Serial.println(F("Sending DATA"));
  client2.println(F("DATA"));
  Serial.println(F("Sending email"));
  client2.println(String("To:example@example.com"));
  // change to your address
  client2.println(F("From: example@example.com"));
  client2.println(F("Subject: stuff\r\n"));
  client2.println(F("Some stuff here\n"));
  client2.println(F("."));
  Serial.println(F("Sending QUIT"));
  client2.println(F("QUIT"));
  client2.stop();
  Serial.println(F("disconnected"));
  return 1;
  //clean FS, for testing
  //SPIFFS.format();
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);
        if (json.success()) {
          Serial.println("\nparsed json");
          strcpy(mqtt_server, json["mqtt_server"]);
          strcpy(mqtt_port, json["mqtt_port"]);
          strcpy(blynk_token, json["blynk_token"]);
          Serial.println("failed to load json config");
    Serial.println("failed to mount FS");
  //end read
  // The extra parameters to be configured (can be either global or just in the setup)
  // After connecting, parameter.getValue() will get you the configured value
  // id/name placeholder/prompt default length
  WiFiManagerParameter custom_mqtt_server("server", "mqtt server", mqtt_server, 40);
  WiFiManagerParameter custom_mqtt_port("port", "mqtt port", mqtt_port, 5);
  WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 32);
  //WiFiManager
  //Local intialization. Once its business is done, there is no need to keep it around
  WiFiManager wifiManager;
  //set config save notify callback
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  //set static ip
  wifiManager.setSTAStaticIPConfig(IPAddress(10,0,1,99), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
  //add all your parameters here
  wifiManager.addParameter(&custom_mqtt_server);
  wifiManager.addParameter(&custom_mqtt_port);
  wifiManager.addParameter(&custom_blynk_token);
  //reset settings - for testing
  //wifiManager.resetSettings();
  //set minimu quality of signal so it ignores AP's under that quality
  //defaults to 8%
  //wifiManager.setMinimumSignalQuality();
  //sets timeout until configuration portal gets turned off
  //useful to make it all retry or go to sleep
  //in seconds
  //wifiManager.setTimeout(120);
  //fetches ssid and pass and tries to connect
  //if it does not connect it starts an access point with the specified name
  //here  "AutoConnectAP"
  //and goes into a blocking loop awaiting configuration
  if (!wifiManager.autoConnect("Example", "example1")) {
    Serial.println("failed to connect and hit timeout");
    delay(3000);
    //reset and try again, or maybe put it to deep sleep
    ESP.reset();
    delay(5000);
  //if you get here you have connected to the WiFi
  Serial.println("connected...yeey :)");
  //read updated parameters
  strcpy(mqtt_server, custom_mqtt_server.getValue());
  strcpy(mqtt_port, custom_mqtt_port.getValue());
  strcpy(blynk_token, custom_blynk_token.getValue());
  //save the custom parameters to FS
  if (shouldSaveConfig) {
    Serial.println("saving config");
    JsonObject& json = jsonBuffer.createObject();
    json["mqtt_server"] = mqtt_server;
    json["mqtt_port"] = mqtt_port;
    json["blynk_token"] = blynk_token;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    json.printTo(configFile);
    configFile.close();
    //end save
  Serial.println("local ip");
 // Set aREST key
  rest.setKey(key, client);
  // Set callback
  client.setCallback(callback);
    rest.set_name("esp8266");
     char* out_topic = rest.get_topic();
     byte ret = sendEmail();
 rest.handle(client);
void callback(char* topic, byte* payload, unsigned int length) {
  rest.handle_callback(client, topic, payload, length);
When adding necesary components of the cloud_pro example from aRest, I encounter these problems as I get to this line:
Did you every found the solution to this problem? I have the same issue with aREST.
