error: '_red' was not declared in this scope (LIBRARY)
Hello guys,
I am making a program for color manipulation on a RGB.
Later in the program it would be very useful to have an instance of each color.
Therefore I followed this simple tutorial provided by arduino: Arduino - LibraryTutorial
I created a library named Color. But when I compile it the following error message shows up:
C:\Users\XPS15\Documents\Arduino\libraries\Color\Color.cpp: In function ‘void setBlueValue(int)’:
C:\Users\XPS15\Documents\Arduino\libraries\Color\Color.cpp:46:3: error: ‘_blue’ was not declared in this scope
_blue = value;
There are 2 of the same errors for the variables _green and _red. There are no further errors.
I tried finding a solution online, but I couldn’t find much on this topic. I hope anyone will help me figure out what’s wrong with my code.
Sketch
#include <Color.h>
#define blueLed 9
#define greenLed 10
#define redLed 11
#define remoteLed 12
Color red(255,0,0, "red");
Color green(0,255,0, "green");
Color blue(0,0,255, "blue");
Color yellow(255,255,0, "yellow");
Color cyan(0,255,255, "cyan");
Color magenta(255,0,255, "magenta");
  pinMode(redLed, OUTPUT);
  pinMode(greenLed, OUTPUT);
  pinMode(blueLed, OUTPUT);
  pinMode(remoteLed, OUTPUT);
  // some code
Color.h
#ifndef Color_h
#define Color_h
#include "Arduino.h"
class Color
  public:
    Color(int red, int green, int blue, String name);
	void setRedValue(int value);
	void setGreenValue(int value);
	void setBlueValue(int value);
	int getRedValue();
	int getGreenValue();
	int getBlueValue();
	String getName();
  private:
    int _red;
	int _green;
	int _blue;
	String _name;
#endif
Color.cpp
#include "Color.h"
Color::Color(int red, int green, int blue, String name)
  _red = red;
  _green = green;
  _blue = blue;
  _name = name;
String Color::getName()
  return _name;
int Color::getRedValue()
  return _red;
int Color::getGreenValue()
  return _green;
int Color::getBlueValue()
  return _blue;
  _red = value;
  _green = value;
  _blue = value;
Do you see an important difference between these two functions?
  return _blue;
  _blue = value;
setRedValue and the similar functions for green and blue are missing something important. You can't access member variables from a function that isn't a member of the class.
vaj4088:
  return _blue;
  _blue = value;
Yes I do now (facepalm). I can't believe I didn't see that. Thank you
