error: a function-definition is not allowed here before '{' token
Hello everybody !
Just beggining with arduino and I have some issue with a parallax sonic ultrasonic.
Error is :
error: a function-definition is not allowed here before ‘{’ token .
The line which cause this is (I think)
long microsecondsToInches(long microseconds)
The entire code is
// this constant won't change.  It's the pin number
// of the sensor's output:
const int pingPin = 7;
const int pompe=12;//Pour controler la pompe
  // initialize serial communication:
  pinMode(pompe,OUTPUT);
  // establish variables for duration of the ping,
  // and the distance result in inches and centimeters:
  long duration, inches, cm;
  // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  pinMode(pingPin, OUTPUT);
  digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  // convert the time into a distance
  inches = microsecondsToInches(duration);
  cm = microsecondsToCentimeters(duration);
  Serial.print(inches);
  Serial.print("in, ");
  Serial.print(cm);
  Serial.print("cm");
  delay(100);
    while(cm <= 5){   //  Tant que la distance entre le parallax et ce qu'il détecte (c'est à dire l'eau) est de moins de 5 cm alors...
       digitalWrite(pompe,HIGH);  // On active la pompe
       if (cm >= 15)  {     // Si la distance entre le parallax ce qu'il détecte (c'est à dire l'eau) est de plus de 15 cm alors...
       digitalWrite(pompe, LOW);      // On éteint la pompe
  // According to Parallax's datasheet for the PING))), there are
  // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
  // second).  This gives the distance travelled by the ping, outbound
  // and return, so we divide by 2 to get the distance of the obstacle.
  // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
  return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
Thanks a lot !!
Merci Beaucoup !
Count the number of left brackets and right brackets and notice that they are not equal, particularly near the end of your loop.
Edit: Arrch beat me to it…
delay(100);
The issue is that you never closed the braces from your if and while. If the code is trying to do what I think, then the program will be stuck inside the while loop as cm will never change inside the loop but, Try this:
...SNIP...
delay(100);
    while(cm <= 5)
       if (cm >= 15)
...SNIP...
Arrch: Count the number of left brackets and right brackets and notice that they are not equal, particularly near the end of your loop.
I recommend that you put each { and } on a line on its own, with matching pairs indented by the same amount and the lines between them indented one extra level. It makes mistakes like this very obvious to spot.
Tools + Auto Format will do this for you, if you don't get it right to start with. Or if you cut and paste code that needs to be indented differently.
PeterH: I recommend that you put each { and } on a line on its own, with matching pairs indented by the same amount and the lines between them indented one extra level. It makes mistakes like this very obvious to spot.
I agree, Allman style FTW :)
