Hi, I'm trying to make a fight stick for a MAME cabinet I'm building. I know that Unojoy seems to be the preferred way of doing this but I couldn't find much about compatibility with Linux. I'm trying to get my Arduino Micro to give keyboard inputs, my previous approach was to take apart a keyboard and use the pcb out of it but this way is more fun and I'm learning more. I have the following code but its giving me these error messages.
fight.ino: In function 'void loop()':
fight:118: error: a function-definition is not allowed here before '{' token
fight:134: error: expected `}' at end of input
That last line repeats probably 15 times. Any help would be much appreciated.
#define KEY_RIGHT 0x4F // Right arrow
#define KEY_LEFT 0x50 // Left arrow
#define KEY_DOWN 0x51 // Down arrow
#define KEY_UP 0x52 // Up arrow
//int horzPin = A0; // Analog output of horizontal joystick pin
//int vertPin = A1; // Analog output of vertical joystick pin
int Button1 = 1; // select pin of Button 1
int Button2 = 2; // select pin of Button 2
int Button3 = 3; // select pin of Button 3
int Button4 = 4; // select pin of Button 4
int Button5 = 5; // select pin of Button 5
int Button6 = 6; // select pin of Button 6
int Button7 = 7; // select pin of Button 7
int Button8 = 8; // select pin of Button 8
int Button9 = 9; // select pin of Button 9
int Button10 = 10; // select pin of Button 10
int up = 11;
int down = 12;
int left = 13;
int right = 14;
pinMode(Button1, INPUT); // set Button select pin as input
digitalWrite(Button1, HIGH); // Pull Button select pin high
pinMode(Button2, INPUT); // set Button select pin as input
digitalWrite(Button2, HIGH); // Pull Button select pin high
pinMode(Button3, INPUT); // set Button select pin as input
digitalWrite(Button3, HIGH); // Pull Button select pin high
pinMode(Button4, INPUT); // set Button select pin as input
digitalWrite(Button4, HIGH); // Pull Button select pin high
pinMode(Button5, INPUT); // set Button select pin as input
digitalWrite(Button5, HIGH); // Pull Button select pin high
pinMode(Button6, INPUT); // set Button select pin as input
digitalWrite(Button6, HIGH); // Pull Button select pin high
pinMode(Button7, INPUT); // set Button select pin as input
digitalWrite(Button7, HIGH); // Pull Button select pin high
pinMode(Button8, INPUT); // set Button select pin as input
digitalWrite(Button8, HIGH); // Pull Button select pin high
pinMode(Button9, INPUT); // set Button select pin as input
digitalWrite(Button9, HIGH); // Pull Button select pin high
pinMode(Button10, INPUT); // set Button select pin as input
digitalWrite(Button10, HIGH); // Pull Button select pin high
pinMode(up, INPUT); // set Button select pin as input
digitalWrite(up, HIGH); // Pull Button select pin high
pinMode(down, INPUT); // set Button select pin as input
digitalWrite(down, HIGH); // Pull Button select pin high
pinMode(left, INPUT); // set Button select pin as input
digitalWrite(left, HIGH); // Pull Button select pin high
pinMode(right, INPUT); // set Button select pin as input
digitalWrite(right, HIGH); // Pull Button select pin high
delay(1000); // short delay to let outputs settle
if (!digitalRead(Button1)){ Keyboard.press('1');}else{Keyboard.release('1');
if (!digitalRead(Button2)){ Keyboard.press('2');}else{Keyboard.release('2');
if (!digitalRead(Button3)){ Keyboard.press('3');}else{Keyboard.release('3');
if (!digitalRead(Button4)){ Keyboard.press('4');}else{Keyboard.release('4');
if (!digitalRead(Button5)){ Keyboard.press('5');}else{Keyboard.release('5');
if (!digitalRead(Button6)){ Keyboard.press('6');}else{Keyboard.release('6');
if (!digitalRead(Button7)){ Keyboard.press('7');}else{Keyboard.release('7');
if (!digitalRead(Button8)){ Keyboard.press('8');}else{Keyboard.release('8');
if (!digitalRead(Button9)){ Keyboard.press('9');}else{Keyboard.release('9');
if (!digitalRead(Button10)){ Keyboard.press('0');}else{Keyboard.release('0');
if (!digitalRead(up)){ Keyboard.press(KEY_UP);}else{Keyboard.release(KEY_UP);
if (!digitalRead(down)){ Keyboard.press(KEY_DOWN);}else{Keyboard.release(KEY_DOWN);
if (!digitalRead(left)){ Keyboard.press(KEY_LEFT);}else{Keyboard.release(KEY_LEFT);
if (!digitalRead(right)){ Keyboard.press(KEY_RIGHT);}else{Keyboard.release(KEY_RIGHT);
void sendKey(byte key, byte modifiers)
KeyReport report = {0}; // Create an empty KeyReport
/* First send a report with the keys and modifiers pressed */
report.keys[0] = key; // set the KeyReport to key
report.modifiers = modifiers; // set the KeyReport's modifiers
report.reserved = 1;
Keyboard.sendReport(&report); // send the KeyReport
/* Now we've got to send a report with nothing pressed */
for (int i=0; i<6; i++)
report.keys[i] = 0; // clear out the keys
report.modifiers = 0x00; // clear out the modifires
report.reserved = 0;
Keyboard.sendReport(&report); // send the empty key report
a lot of this is a copy paste from another source, I'm not gonna lie.
Thank you
