Error - Arduino micro, virtualwire and servotimer2
Hi, i'm trying to use virtualwire and servotimer2 libraries together, but the problem is that arduino micro doesn't have a timer2 and I don't find any library that i can use to replace servotimer2 library without using timer1 that goes in conflict with virtualwire. Any suggestions?
Which arduino doe's not have time 2 mine do.
Mark
I see that microcontroller of arduino micro is an ATmega32u4 that doesn’t have a timer2 (try searching on google), in fact when I try to verify an example sketch of the servotimer2 library give me error, but if I change the board in tool/boards with a board that doesn’t have an ATmega32u4 all work fine.
So I have to buy another arduino boards, like arduino UNO, or there is a solution to this problem?
holmes4: Which arduino doe's not have time 2 mine do.
Boards based on the ATmega32u4 do not have a timer2. Currently that's the Leonardo and Micro.
Megas112: So I have to buy another arduino boards, like arduino UNO, or there is a solution to this problem?
Get a different board or re-write the library if someone else hasn't already.
Thanks you very much for your answer.
